Maniphest T64438
Collection Instance object highlight wrong
Closed, Resolved
Dalai Felinto (dfelinto)
Sebastian Koenig (sebastian_k)
May 10 2019, 2:57 PM
  • BF Blender
Brecht Van Lommel (brecht)
Clément Foucault (fclem)
Michael Soluyanov (crantisz)
Philipp Oeser (lichtwerk)
Sebastian Parborg (zeddb)
Tokens
"Party Time" token, awarded by crantisz.
Operating system: elementaryOS 0.4.1
Graphics card: GTX 1080
Broken: 2.80, 259ebdd01725
Worked: did work couple of revisions back
Objects in nested Collections are highlighted wrong when selected. In one case the Empty Axis itself is highlighted correctly, while the outline is not highlighted. In the other case the object gets highlighted when the collection instance is highlighted, even though the object instance isn't even part of the collection. It's kinda hard to describe...
Open this file.
The scene 'Scene.001' is open, where I have created 2 collection instances.
Notice how the object 'cube_instance' has a highlighted origin, but not the outline.
However, if you select the object 'supergroup', there are two cubes highlighted, even though only one of them is actually part of the collection.
The Objects and Collections are setup in the other scene 'Scene'.
Somehow the nesting messes up the selection highlighting.
Revisions and Commits
rB Blender
Related Objects
Mentioned In
T66295: Collection instance duplicates don't have selection outline
rB5df4c0a4693c: Outliner: Fix selecting collections in view layer selecting original objects
Mentioned Here
rBb6b3a57c2241: DRW: Add DRW_duplidata_get to create fast path for duplis
rB6df7946f7360: Object Overlay: Add dupli fast path
rB259ebdd01725: Fix failing tests when Cycles is enabled
Sebastian Koenig (sebastian_k) created this task.May 10 2019, 2:57 PM
Sebastian Koenig (sebastian_k) added a subscriber: Dalai Felinto (dfelinto).May 16 2019, 9:08 AM
Found an interesting twist to this bug.
I have created a collection instance of the collection 'supergroup' in the first Scene, called 'supergroup_instance'.
If you open this file
'supergroup_instance' is selected. But only the Empty crosses of it are highlighted, not the outline.
Now if you exclude the collection 'supergroup' from the viewlayer with the checkmark toggle, 'supergroup_instance' becomes highlighted.
Sounds like something for @Dalai Felinto (dfelinto)? :)
Dalai Felinto (dfelinto) claimed this task.May 16 2019, 4:43 PM
Dalai Felinto (dfelinto) added a subscriber: Brecht Van Lommel (brecht).May 24 2019, 5:22 PM
Before getting into your more complicated file I reproduce some strange behaviour that I will look at it first:
To reproduce the bug just select the "A - I have a torus" collection that is INSIDE the "B - I instanced a torus"
What to expect: Nothing gets selected.
What we get: The torus gets selected.
Note: The camera is there so you can reliably reset the selected object.
Dalai Felinto (dfelinto) added a comment.May 24 2019, 7:56 PM
My suggestion which I will look at:
  1. In View Layer clicking in a collection NEVER select its objects.
  2. In Scenes and Blender File we can keep this behaviour.
  3. Selecting the instance (Empty) itself should should the instanced collection as selected..
Dalai Felinto (dfelinto) mentioned this in rB5df4c0a4693c: Outliner: Fix selecting collections in view layer selecting original objects.May 24 2019, 11:51 PM
Sebastian Parborg (zeddb) lowered the priority of this task from 90 to 50.Jun 11 2019, 3:39 PM
Sebastian Parborg (zeddb) added a subscriber: Sebastian Parborg (zeddb).
I'll mark this as confirmed as it seems like it has been reproduced and a partial fix has already made it in.
Michael Soluyanov (crantisz) added a subscriber: Michael Soluyanov (crantisz).Jun 12 2019, 1:50 PM
Affects me to.
here the step, were it was broken:
Broken: version: 2.80 (sub 74), branch: blender2.7, commit date: 2019-06-11 21:45, hash: rBd93a7290e506
Broken: version: 2.80 (sub 61), branch: blender2.7, commit date: 2019-05-12 22:25, hash: rB05f1451d7248
Worked: version: 2.80 (sub 60), branch: blender2.7, commit date: 2019-05-07 19:17, hash: rB3dc9da3a74ee
beetween 60 and 61 subversions.
here my test file:
Looks like instance outlines only if first instance selected also,
Philipp Oeser (lichtwerk) added subscribers: Clément Foucault (fclem), Philipp Oeser (lichtwerk).Jul 1 2019, 12:24 PM
Just bisected a seemingly related task (T66295), and that one was broken by rB6df7946f7360, rBb6b3a57c2241, so adding @Clément Foucault (fclem) here... [not quite sure if these are indeed duplicates...]
Clément Foucault (fclem) changed the task status from Unknown Status to Resolved by committing rB57c26453f8aa: Fix T66295 Collection instance duplicates don't have selection outline.Jul 2 2019, 4:04 PM
Clément Foucault (fclem) added a commit: rB57c26453f8aa: Fix T66295 Collection instance duplicates don't have selection outline.
Michael Soluyanov (crantisz) awarded a token.Jul 2 2019, 4:42 PM
