Maniphest T65007
Linked curves with curve modifiers are not deformed correctly
Closed, Duplicate
None
Artem (Hickz)
May 22 2019, 11:32 PM
  • BF Blender
  • Tracker Curfew
Artem (Hickz)
Brecht Van Lommel (brecht)
Graphics card: GeForce GTX 1060 6GB/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 391.01
Broken: version: 2.80 (sub 71), branch: master, commit date: 2019-05-22 17:52, hash: rB8fdbd1377e53
Worked:
Linked curves (CTRL+D) with curve modifiers are not deformed correctly with this button enabled
. Ctrl+A again doesn’t work properly (like you didnt have a modifier for the curve in the first place). If you make single user the "linked curve" it starts to deform correctly, if it stays linked it's broken.
Here's a file that shows all the problems above:
Literally try CTRL+A on any of them.
Also see the strange behavior of the "linked curve".
Artem (Hickz) created this task.May 22 2019, 11:32 PM
Brecht Van Lommel (brecht) updated the task description.May 22 2019, 11:48 PM
Brecht Van Lommel (brecht) added a subscriber: Brecht Van Lommel (brecht).
Please create one report per bug. It is also not necessary to report bugs twice, this one is still open:
T63871: Curves with curve modifiers are not translated to mesh correctly and can't be used as a target for constraints and modifiers predictably
Brecht Van Lommel (brecht) renamed this task from "Convert to" and curves/text are completely broken to Linked curves with curve modifiers are not deformed correctly.May 22 2019, 11:49 PM
Artem (Hickz) added a comment.May 23 2019, 12:04 AM
@Brecht Van Lommel (brecht)
I thought it would be easier to show all of it in 1 file because it all seems related. So there's a problem with CTRL+A, curves with modifiers on them, and linked curves with modifiers on them. Do you think this covers it all or should i create another bug report?
Brecht Van Lommel (brecht) lowered the priority of this task from 90 to 50.May 23 2019, 2:13 AM
For the other bug it appears we already have. So that leaves one bug for this report.
T60868: Adjust Last Operation Panel Disappears After Convert Curve To Mesh > Keep Original
Dalai Felinto (dfelinto) added a project: Tracker Curfew.Dec 23 2019, 4:34 PM
