Maniphest T65111
cant launch blender
Closed, Archived
Brecht Van Lommel (brecht)
fadil fikrillah (fikrillah)
May 25 2019, 11:05 AM
  • BF Blender
Bastien Montagne (mont29)
dark999 (dark999)
Sebastian Parborg (zeddb)
Operating system: archlinux
Graphics card: nvidia 430.14
Broken: 2019-05-24
cant run blender, error message:
Color management: using fallback mode for management
Color management: Error could not find role data role.
Writing: blender.crash.txt
zsh: segmentation fault (core dumped)  ./blender
Related Objects
Mentioned In
T67722: Blender cant run at all
Mentioned Here
rB79ce2054d436: Linux: add script and instructions for creating snap packages
fadil fikrillah (fikrillah) created this task.May 25 2019, 11:05 AM
Brecht Van Lommel (brecht) lowered the priority of this task from 90 to 30.May 25 2019, 9:00 PM
Brecht Van Lommel (brecht) added a subscriber: Brecht Van Lommel (brecht).
This seems like an incomplete download, as if some files are missing. Can you try downloading and unpacking Blender again?
fadil fikrillah (fikrillah) added a comment.May 26 2019, 6:43 PM
well, it happen sometimes, by the time that happen, it was in the latest git version.
but i just did make update, it works fine...
fadil fikrillah (fikrillah) added a comment.May 27 2019, 10:09 AM
and it doesn't work now after restart. i updated it again and still error
Brecht Van Lommel (brecht) added a comment.May 27 2019, 11:44 PM
Since you mention make update, it seems like you are making your own build. Most likely there is something wrong in the setup then, but it's not possible for us to guess what.
For questions about building Blender, this would be the right place to task, with explanation of how exactly you setup up the build and build logs:
https://devtalk.blender.org/c/blender/building-blender
Brecht Van Lommel (brecht) changed the task status from Unknown Status to Unknown Status.Jun 7 2019, 11:20 AM
fadil fikrillah (fikrillah) added a comment.Jul 18 2019, 4:13 PM
i've tried reinstall my system, blender can't launch everytime. tried official distro package (2.79) have same issue, tried download from blender.org, same issue
here's the log from blender.org package
Robert Guetzkow (rjg) mentioned this in T67722: Blender cant run at all.Jul 26 2019, 11:24 AM
Demeter Dzadik (Mets) changed the task status from Unknown Status to Unknown Status.EditedJul 26 2019, 1:49 PM
Demeter Dzadik (Mets) added a subscriber: Demeter Dzadik (Mets).
Re-opening this since the problem persists. Closed T67722.
I find it odd that it worked after you re-downloaded at one point, but broke again after restart. Maybe a faulty hard drive? Is there other software that you use on this computer that works as expected?
fadil fikrillah (fikrillah) added a comment.Jul 26 2019, 10:10 PM
My system is fine, tried reinstall my distro, but still no luck. It was working like 1/2 of the time. But now it's not working at all. All other software is working just fine...
dark999 (dark999) added a subscriber: dark999 (dark999).Jul 26 2019, 11:18 PM
Please, update this report following strictly this form https://developer.blender.org/maniphest/task/edit/form/1/
The operating system, main memory size, GPU brand and model, GPU driver version and Blender hash or its build date may be needed by developers to investigate this issue
You can check here https://www.blender.org/download/requirements/ if your hardware and software meet minimum Blender requirement
do you build your Blender from the source or do you use a precompiled Blender? you can try to download a pre-compiled version from here https://www.blender.org/download/ for the Release Candidate 3, at the bottom of this page you can find a dailybuild, it's a little more correct than RC3
fadil fikrillah (fikrillah) added a comment.Jul 28 2019, 5:34 AM
Operating system: Arch Linux (current)
Graphics card:
$ lspci -vnn | grep VGA -A 12
09:00.0 VGA compatible controller [0300]: NVIDIA Corporation GP106 [GeForce GTX 1060 6GB] [10de:1c03] (rev a1) (prog-if 00 [VGA controller])
Subsystem: ZOTAC International (MCO) Ltd. GP106 [GeForce GTX 1060 6GB] [19da:1438]
Flags: bus master, fast devsel, latency 0, IRQ 68
Memory at fc000000 (32-bit, non-prefetchable) [size=16M]
Memory at e0000000 (64-bit, prefetchable) [size=256M]
Memory at f0000000 (64-bit, prefetchable) [size=32M]
I/O ports at e000 [size=128]
[virtual] Expansion ROM at 000c0000 [disabled] [size=128K]
Capabilities: <access denied>
Kernel driver in use: nvidia
Kernel modules: nouveau, nvidia_drm, nvidia
System memory: 8Gb
nvidia driver version: 430.34-3
any blender version i've tried (from 2.79 up) from many sources, but for the sake of this report 79ce2054d436 from blender.org
blender doesnt launch
double click on the binary
Demeter Dzadik (Mets) raised the priority of this task from 30 to 90.Jul 28 2019, 12:44 PM
Demeter Dzadik (Mets) added a comment.Jul 28 2019, 12:50 PM
I would say wipe your user preferences, but if you reinstalled your entire system then that's not gonna help either. Hopefully a dev will have any idea, but since Brecht's guess didn't help, I don't know what will. :/ I will pray for your Blender.
dark999 (dark999) added a comment.EditedJul 28 2019, 1:13 PM
@fadil fikrillah (fikrillah) please, can you check if any 32 bit blender version work on your system?
your system use a nouveau drivers, blender stiil not working on it, it ia know issue on drivers side
fadil fikrillah (fikrillah) added a comment.Jul 28 2019, 5:02 PM
32bit has save result. ill try nouveau
i dont know it would be helpful, but it seems like someone else on the net also have same message:
blender: symbol lookup error: blender: undefined symbol: _ZN7Alembic3Abc3v117OObject14getChildHeaderERKNSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEE
dark999 (dark999) added a comment.Jul 28 2019, 5:52 PM
@fadil fikrillah (fikrillah) you already use nouveau, you MUST disable it and install properly proprietary Nvidia drivers
in your system info we can see Kernel modules: nouveau, nvidia_drm, nvidia, this is relate to nouveau not Nvidia drivers
fadil fikrillah (fikrillah) added a comment.Jul 28 2019, 7:16 PM
the wiki says, when nvidia is installed. it automatically blacklist nouveau. and also one line above it
Sebastian Parborg (zeddb) lowered the priority of this task from 90 to 30.Aug 5 2019, 11:46 AM
Sebastian Parborg (zeddb) added a subscriber: Sebastian Parborg (zeddb).
Just to be clear, you get the same error message when building blender yourself or using the precompiled build bot version?
fadil fikrillah (fikrillah) added a comment.Aug 7 2019, 6:49 AM
yes, tried from many sources, i still get the message...
dark999 (dark999) added a comment.Aug 7 2019, 9:12 AM
@fadil fikrillah (fikrillah) in terminal write: sudo lsmod | grep nvidia if you see nvidia as output you use proprietary Nvidia drivers, else you not have properly installed these and use nouveau drivers instead. To confirm this you can write in terminal sudo lsmod | grep nouveau and you see this drivers loaded in kernel. to work only one nvidia GPU drivers can be loaded in kernel
fadil fikrillah (fikrillah) added a comment.Aug 7 2019, 10:35 AM
$ sudo lsmod | grep nvidia
nvidia_drm 57344 6
nvidia_modeset 1118208 9 nvidia_drm
nvidia 19103744 374 nvidia_modeset
drm_kms_helper 225280 1 nvidia_drm
drm 503808 9 drm_kms_helper,nvidia_drm
ipmi_msghandler 69632 2 ipmi_devintf,nvidia
$ sudo lsmod | grep nouveau
well this is output i got
Demeter Dzadik (Mets) removed a subscriber: Demeter Dzadik (Mets).Aug 7 2019, 11:15 AM
Bastien Montagne (mont29) added a subscriber: Bastien Montagne (mont29).Aug 20 2019, 12:12 PM
Crash seems to happen in GHost while trying to refresh list of input devices. Do you have any "non-standard" devices? Like a 3D mouse, a tablet, etc? Can you try to unplug everything but a regular keyboard and mouse, and see whether Blender starts for you then?
This definitively looks like a specific system setup issue...
Bastien Montagne (mont29) changed the task status from Unknown Status to Unknown Status.Aug 27 2019, 12:16 PM
