Maniphest T66025
RBG node crashes Blender 2.8
Closed, Resolved
Brecht Van Lommel (brecht)
Viktors (DageLV)
Jun 22 2019, 7:38 PM
  • BF Blender
Alessio Monti di Sopra (a.monti)
Viktors (DageLV)
Operating system: Windows 10 home
Graphics card: Nvidia GTX 730
Broken: 2.80.0, Date: 2019-06 22 15:47, Hash: ab9492648398
Worked: 2.79
Editing RBG node ?intensity? value crashes blender
make an object with metalic material template from 2.79, use latest blender to use it, then change RBG intensity of the RBG node. Crash. I can change the color, but the second i touch intensity, it crashes.
now when i reduced the size of that blend file to upload here and experimenting with it, even changing materials name may cause blender to crash. Basically, here is the blend file, play with the materials. Change RBG values to all of them and change the names, blender crashes. If anyone has temp solution, mind sharing it?
Related Objects
Mentioned Here
T66026: CTest/Cycles subdiv related failures
rBae6300a8b74b: Fix T66022: crash adding subdivision surface modifier to some meshes
rBab9492648398: GPencil: Fix Fast Drawing and MSAA disabled in previous commit
Viktors (DageLV) created this task.Jun 22 2019, 7:38 PM
Viktors (DageLV) added a comment.Jun 22 2019, 7:44 PM
Renaming material "Base" to something else also caused blender to crash.
Brecht Van Lommel (brecht) lowered the priority of this task from 90 to 30.Jun 23 2019, 12:13 AM
Brecht Van Lommel (brecht) added a subscriber: Brecht Van Lommel (brecht).
Please try installing the latest graphics drivers from the NVIDIA website.
If that doesn't help, please attach the output of Help > Save System Info.
Viktors (DageLV) renamed this task from RBG node crashes Blender 2.9 to RBG node crashes Blender 2.8.Jun 23 2019, 10:13 AM
Viktors (DageLV) updated the task description.Jun 23 2019, 10:16 AM
Brecht Van Lommel (brecht) raised the priority of this task from 30 to 90.Jun 23 2019, 11:43 AM
Alessio Monti di Sopra (a.monti) added a subscriber: Alessio Monti di Sopra (a.monti).Jun 23 2019, 11:55 AM
@Brecht Van Lommel (brecht) I think this also got resolved by ae6300a8b74b
I had crashes modifying material parameters with the same call stack of T66026
Brecht Van Lommel (brecht) changed the task status from Unknown Status to Resolved.Jun 23 2019, 6:05 PM
Assuming it is resolved then, we can reopen the report if it's not the case.
Viktors (DageLV) added a comment.Jun 23 2019, 11:26 PM
i used the latest blender version, i downloaded it the day i made this post.
Brecht Van Lommel (brecht) added a comment.Jun 26 2019, 3:27 AM
Right, the fix was done after this report was created.
