Maniphest T66067
Bevel corrupts UVs
Closed, Duplicate
None
Robin Karlsson (nosslak)
Jun 24 2019, 1:20 AM
  • BF Blender
Operating system: Windows 10 64-bit
Graphics card: Geforce GTX 270
Broken: 2.80 e7a0f0a9934e
The UV modifier and operator corrupts the UVs of models. Here is an image showing the problem:
First model is the raw, unwrapped basemesh I want to bevel, second is what it looks like after I add a bevel modifier, third is the desired result (manually fixed).
Here's a blendfile with the three models from above:
Just apply any tiling texture with strong vertical lines and you'll be able to see the issue clearly.
Related Objects
Mentioned Here
rBe7a0f0a9934e: UI: Rename "Draw Thin" to "Display Thin"
Robin Karlsson (nosslak) created this task.Jun 24 2019, 1:20 AM
Brecht Van Lommel (brecht) closed this task as a duplicate of T56625: Bevel modifier UV problem with corners.Jun 24 2019, 1:52 PM
