Maniphest T66082
Slider Dragging Crash
Closed, Archived
Jacques Lucke (JacquesLucke)
Jonathan Gower (Skyn-E)
Jun 24 2019, 5:26 PM
  • BF Blender
Brecht Van Lommel (brecht)
Gavin Scott (Zoot)
Operating system: Windows 10 64bit May Update
Graphics card: Nvidia GTX 1060 6GB
Broken: 22/6/2019 Blender 2.8 Hash ab9492648398
Blender just crashes back to desktop with no error when dragging on sliders, Is intermittent, You can drag it and its fine then drag another one and it crashes, maybe related to the speed its dragged
Related Objects
Mentioned In
T66057: A sudden shutdown of the program
Mentioned Here
rBab9492648398: GPencil: Fix Fast Drawing and MSAA disabled in previous commit
Jonathan Gower (Skyn-E) created this task.Jun 24 2019, 5:26 PM
Alessio Monti di Sopra (a.monti) mentioned this in T66057: A sudden shutdown of the program.Jun 24 2019, 10:33 PM
Jonathan Gower (Skyn-E) added a comment.Jun 25 2019, 7:32 PM
Ive also noticed that Ctrl Z, Undo actioning a few times in a row is also causing it to just drop back to the desktop
Brecht Van Lommel (brecht) lowered the priority of this task from 90 to 30.Jun 26 2019, 6:06 PM
Brecht Van Lommel (brecht) added a subscriber: Brecht Van Lommel (brecht).
We require a .blend file and steps to reproduce the problem.
Jonathan Gower (Skyn-E) added a comment.Jun 26 2019, 8:00 PM
Here is the blend file im am currently working with, I was following a youtube tutorial on creating and animating a character, If you try and undo more than a few steps it will crash to the desktop, and also happens sometimes moving sliders
Brecht Van Lommel (brecht) raised the priority of this task from 30 to 90.Jun 27 2019, 4:21 PM
Gavin Scott (Zoot) added a subscriber: Gavin Scott (Zoot).Jul 3 2019, 6:40 PM
Which sliders?
I made a dozen bone changes and was able to undo all the way back without issues. Can you provide a reproducible example of a sequence that results in a crash?
Jonathan Gower (Skyn-E) added a comment.Jul 5 2019, 3:25 PM
Just tried a new blend file and clicked and dragged in the Colour Wheel in the material tab and while dragging around quite fast it dropped back to the desktop. After reloading and doing it again it was fine and didn't crash even dragging around really quick for like thirty seconds, I couldn't get it to crash doing the same thing with the sliders in the material tab even though it happened before with them. I even reloaded that turtle file and tried dragging around the colour wheel and sliders and it didn't crash, so im not sure whats going on because I worked with that file for like a week and it crashed several times a day. I will probably just update to the latest daily build or wait for the final release
Jacques Lucke (JacquesLucke) changed the task status from Unknown Status to Unknown Status.Aug 7 2019, 3:41 PM
Jacques Lucke (JacquesLucke) claimed this task.
Jacques Lucke (JacquesLucke) added a subscriber: Jacques Lucke (JacquesLucke).
Closing since not even @Jonathan Gower (Skyn-E) was able to reproduce it anymore.
Please create a new report when the problem happens again (and provide a simple file to reproduce the issue).
