Maniphest T66180
Blender 2.80beta - FBX import missing textures + deformed animations
Confirmed, NormalKNOWN ISSUE
None
Mark Bell (AMB4552)
Jun 27 2019, 1:43 PM
  • Import/Export
  • Add-ons (BF-Blender)
Adam Preisler (Alphisto)
Bastien Montagne (mont29)
Demeter Dzadik (Mets)
Mark Bell (AMB4552)
Robert Guetzkow (rjg)
Stephen Swaney (stiv)
Operating system: Win10Pro (10.0.17134 Build 17134) 64 bit
Graphics card: NVIDIA Quadro K4200
Broken: (example: 2.80beta, Hash 93f170390071 Date 2019.06.26 13.42
  1. Imported FBX file from free ANIMA web site (rp_sophia_animated_003_idling.fbx),
  2. mesh model imports ok, but imports with model on side and needs rotating to stand vertical on correct axis,
  3. no textures import, even after setting correct paths,
  4. animation playback deforms the model and is different each time it is loaded,
  5. mesh model includes a number of armatures 'floating' off the model - appears the axis may be wrong for some?
Based on the default startup file then import the above fbx file.
Related Objects
Mentioned In
T68575: FBX Known issues & TODO's
Mentioned Here
rB93f170390071: Buildbot: Preliminary support for CentOS based builder
Mark Bell (AMB4552) created this task.Jun 27 2019, 1:43 PM
Mark Bell (AMB4552) added a comment.Jun 27 2019, 11:41 PM
I've managed to rectify the import of textures so this issue can be removed from my list.
Stephen Swaney (stiv) lowered the priority of this task from 90 to 30.Jun 29 2019, 12:53 AM
Stephen Swaney (stiv) added a subscriber: Stephen Swaney (stiv).
Do you have an .fbx showing the problem?
Mark Bell (AMB4552) added a comment.Jun 30 2019, 2:04 AM
Hello Stephen,
Dropbox link to the fbx files - https://www.dropbox.com/s/mu92mw122hfctcr/rp_sophia_animated_003_idling_FBX.zip?dl=0
I've also attached two screenshots showing the model deformation.
Thanks.
Demeter Dzadik (Mets) raised the priority of this task from 30 to 90.EditedJul 24 2019, 4:20 PM
Demeter Dzadik (Mets) added a subscriber: Demeter Dzadik (Mets).
After rotating the mesh 90 degrees such that it aligns with the armature, the animations seem to work fine. Texture imports too.
So I think the only issue here is that rotation issue, which I've seen before in fbx imports sometimes, but it's a relatively small problem considering it is FBX. I don't think this needs information from user anymore, but I also doubt this will get fixed, since time would be better spent on USD support and deleting all memory of FBX from this corporeal realm. Let's wait for a dev to decide.
Also: In future please attach files directly here instead of linking to external sites. I uploaded that dropbox zip here:
Adam Preisler (Alphisto) added subscribers: Campbell Barton (campbellbarton), Adam Preisler (Alphisto).Sep 18 2019, 12:05 PM
I think this one is to be closed by @Campbell Barton (campbellbarton) or remain open forever.
Philipp Oeser (lichtwerk) edited projects, added Add-ons (Community), Import/Export; removed BF Blender.Nov 20 2019, 12:46 PM
Bastien Montagne (mont29) added a project: Python API.May 27 2020, 12:11 PM
Bastien Montagne (mont29) changed the subtype of this task from "Report" to "Bug".
Bastien Montagne (mont29) mentioned this in T68575: FBX Known issues & TODO's.
Campbell Barton (campbellbarton) moved this task from Backlog to Under Discussion on the Python API board.Jun 18 2020, 3:14 PM
Campbell Barton (campbellbarton) removed a project: Python API.Jun 18 2020, 3:52 PM
Bastien Montagne (mont29) edited projects, added Add-ons (BF-Blender); removed Add-ons (Community).Jul 28 2020, 11:03 AM
Bastien Montagne (mont29) moved this task from Backlog to Long Term on the Add-ons (BF-Blender) board.Jul 28 2020, 11:08 AM
Robert Guetzkow (rjg) changed the task status from Needs Triage to Confirmed.Nov 23 2020, 12:47 PM
Robert Guetzkow (rjg) changed the subtype of this task from "Bug" to "Known Issue".
Robert Guetzkow (rjg) added subscribers: Bastien Montagne (mont29), Robert Guetzkow (rjg).
@Bastien Montagne (mont29) I'm marking this as confirmed and Known Issue, just like the other tickets listed in T68575
