Maniphest T66192
Transform Tool Issues: Orphaned Label and Redundant Drag Action
Closed, ResolvedBUG
Dan Pool (dpdp)
Jun 27 2019, 11:32 PM
  • BF Blender
Dan Pool (dpdp)
William Reynish (billreynish)
Graphics card: Quadro P4000/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 397.44
Broken: version: 2.80 (sub 74), branch: soc-2019-cycles-procedural, commit date: 2019-06-26 12:11, hash: rBc373811abd92
The Transform active tool displays an orphaned label in the tool settings top bar that reads
Gizmos:
No property or button follows. In earlier builds, this is where the user could turn on or off individual transform gizmos, but that functionality no longer exists.
In the same tool, the None and Move Drag Action settings do the same thing.
  • With the default cube scene open, enable the Transform active tool.
  • Right Click the 3d View Header and select Header > Show Tool Settings
  • Observe the "Gizmos:" orphaned text
  • Set the drag action first to None and then to Move, dragging in the viewport each time.
Revisions and Commits
rB Blender
Dan Pool (dpdp) created this task.Jun 27 2019, 11:32 PM
Dan Pool (dpdp) added a comment.Jun 27 2019, 11:35 PM
These issues with the tool settings have been in every daily build since the Transform tool was reintroduced over a month ago.
William Reynish (billreynish) assigned this task to Campbell Barton (campbellbarton).Jun 28 2019, 11:10 AM
William Reynish (billreynish) lowered the priority of this task from 90 to High.
William Reynish (billreynish) added a subscriber: William Reynish (billreynish).
The missing gizmos is a bug.
The drag action thing should not have an option for None (nothing makes no sense) - instead, if should be set to Box Select by default.
David Allen Arteaga (Codename.REL.aitive) claimed this task.Jun 29 2019, 6:13 PM
David Allen Arteaga (Codename.REL.aitive) added subscribers: Campbell Barton (campbellbarton), David Allen Arteaga (Codename.REL.aitive).
Brecht Van Lommel (brecht) reassigned this task from David Allen Arteaga (Codename.REL.aitive) to Campbell Barton (campbellbarton).Jun 30 2019, 11:04 PM
Brecht Van Lommel (brecht) removed a subscriber: David Allen Arteaga (Codename.REL.aitive).
Campbell Barton (campbellbarton) changed the task status from Unknown Status to Resolved by committing rB1a5e1273c1cb: Fix T66192: Remove gizmos label from topbar.Jul 1 2019, 5:26 AM
Campbell Barton (campbellbarton) added a commit: rB1a5e1273c1cb: Fix T66192: Remove gizmos label from topbar.
Campbell Barton (campbellbarton) added a comment.EditedJul 1 2019, 5:28 AM
Corrected gizmo label, the issue with None is more a keymap design issue.
  • With right click select, this does what you would expect.
  • With left click select, the 3d view has a keymap item that uses LMB-drag to move (no matter what tool is selected).
  • So even when the tool doesn't handle the event, it is passed through to the 3D views keymap which does.
