Maniphest T66397
Bone Constraint Child Of Bone + Follow Path Bone
Closed, Resolved
Philipp Oeser (lichtwerk)
Hawick Inkster (animynous)
Jul 4 2019, 2:41 AM
  • BF Blender
  • Dependency Graph
Graphics card: Quadro K3000M/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 416.78
Broken: version: 2.80 (sub 74), branch: master, commit date: 2019-07-01 15:48, hash: rBdcf520cdad79
Worked: 2.79
When the target has a Follow Path constraint, the Set Inverse function of the Child Of bone gives unexpected results, it repositions the Child Of bone, but not to it's Rest Position.
Create a Curve object.
Attach curves vertices to "hook" bones to deform.
Add a bone at world origin, and add Follow Path constraint using the above curve as the target.
Add another bone at it's intended rest position, add a Child of constraint with the target being the Follow Path bone.
Child Of bone is offset from its rest position/rotation.
Set Inverse, Child of bone moves, but not to its rest position/rotation.
All bones are in the same armature.
Revisions and Commits
rB Blender
D5189
Related Objects
Mentioned Here
rB609e16339f13: Fix "child of" constraint "set inverse" problematic with bones
T66080: Bone vertex Child of Constraint problem
Hawick Inkster (animynous) created this task.Jul 4 2019, 2:41 AM
Philipp Oeser (lichtwerk) lowered the priority of this task from 90 to 30.Jul 4 2019, 10:17 AM
Philipp Oeser (lichtwerk) added a project: Dependency Graph.
I think this might be the same as T66080.
Just to make sure: could you post a .blend with your current setup? [I know it is not too complicated, but saves us some time setting this up, especially if multiple devs have a look at this...]
(thx in advance)
Hawick Inkster (animynous) added a comment.Jul 4 2019, 10:23 AM
Blend file example of issue.
Philipp Oeser (lichtwerk) claimed this task.Jul 4 2019, 10:35 AM
Philipp Oeser (lichtwerk) raised the priority of this task from 30 to 50.
Thx for getting back.
Seems this has the same reasons as T66080, checking... [might merge these two if same reasons apply...]
Philipp Oeser (lichtwerk) changed the task status from Unknown Status to Resolved by committing rB609e16339f13: Fix "child of" constraint "set inverse" problematic with bones.Jul 5 2019, 4:02 PM
Philipp Oeser (lichtwerk) added a commit: rB609e16339f13: Fix "child of" constraint "set inverse" problematic with bones.
Philipp Oeser (lichtwerk) added a comment.Jul 5 2019, 4:04 PM
committed a fix now (rB609e16339f13), thorough testing is welcome :)
