Maniphest T66533
Export selected in X3D fails with selected parts
Closed, Archived
Bastien Montagne (mont29)
Nigel Johnson (nigeljohnson73)
Jul 7 2019, 4:12 PM
  • Add-ons (Community)
Brendon Murphy (meta-androcto)
should not be asked (vwvw)
Sybren A. Stüvel (sybren)
Operating system: Darwin-18.6.0-x86_64-i386-64bit 64 Bits
Graphics card: AMD Radeon Pro Vega 64 OpenGL Engine ATI Technologies Inc. 4.1 ATI-2.9.26
Broken: version: 2.80 (sub 74), branch: master, commit date: 2019-07-04 22:24, hash: rBfdcfc263e973
When Exporting an X3D model and choosing the only selected option, the export bombs with an error message saying no object has attribute "select"
Add a model and select it
Select file->export->X3D
click "Selection Only"
Then export
Related Objects
Mentioned In
T66534: X3D export in 2.80 does not save texture
Mentioned Here
rB785301e5acfb: Annotation: Simplify only 3D annotations and reduce factor
Nigel Johnson (nigeljohnson73) created this task.Jul 7 2019, 4:12 PM
Nigel Johnson (nigeljohnson73) mentioned this in T66534: X3D export in 2.80 does not save texture.Jul 7 2019, 4:18 PM
Brecht Van Lommel (brecht) edited projects, added Add-ons (Community); removed BF Blender.Jul 7 2019, 7:30 PM
Brendon Murphy (meta-androcto) lowered the priority of this task from 90 to 30.Jul 23 2019, 12:31 PM
Brendon Murphy (meta-androcto) added a subscriber: Brendon Murphy (meta-androcto).
hi, just tested this in rc2, unable to reproduce this error. Tested on windows. @Nigel Johnson (nigeljohnson73) can you test again with 2.8 rc2 please.
Nigel Johnson (nigeljohnson73) added a comment.Jul 24 2019, 2:19 PM
Tested on Win10 and 2.80 RC2, now error says "name" from "mesh" is read only.
Sybren A. Stüvel (sybren) added a subscriber: Sybren A. Stüvel (sybren).Aug 6 2019, 1:58 PM
I can't reproduce this on current master (785301e5acfbf55208655aba80cde5b2d7b2ee44) by exporting Suzanne to X3D.
@Nigel Johnson (nigeljohnson73) please update the task with a minimal example blend file that shows this problem.
Bastien Montagne (mont29) changed the task status from Unknown Status to Unknown Status.Aug 13 2019, 5:50 PM
Bastien Montagne (mont29) added a subscriber: Bastien Montagne (mont29).
should not be asked (vwvw) added a subscriber: should not be asked (vwvw).Jan 13 2020, 4:47 PM
Hey, I encountered the same error today
Failing on Blender 2.81.a
Sybren A. Stüvel (sybren) added a comment.Jan 14 2020, 2:59 PM
@should not be asked (vwvw) The original report was about reading the value of a non-existing select attribute. You seem to face an assignment to a read-only name attribute. This means it's a different issue, so please file a separate bug report about this.
