Maniphest T66656
Rigify is broken
Closed, Archived
Brecht Van Lommel (brecht)
david law (Ponlets)
Jul 10 2019, 11:45 AM
  • Add-ons (Community)
david law (Ponlets)
Sybren A. Stüvel (sybren)
Operating system: windows 10 pro 64bit
Graphics card: GTX 1080 ti
Broken:
(example: 2.79b release)
Blender 2.79
rigify 0.5
i added the meta human rig which should have all the bone and rig groups set up and did nothing but position the bones without adding them to my character model just to get a basic idea of where to put them and i then clicked generate new rig and this error set (image attached) came up and i cant get around it and i dont know why
google is no help and other forums are dead ends
what i did was i added the meta human rig (with the face bits not the simple one but the complex one) and moved the bones to where they should be and then clicked "generate new rig"
Related Objects
david law (Ponlets) created this task.Jul 10 2019, 11:45 AM
Brecht Van Lommel (brecht) lowered the priority of this task from 90 to 30.Jul 10 2019, 1:29 PM
Brecht Van Lommel (brecht) added a subscriber: Brecht Van Lommel (brecht).
Please test if it's still an issue in the latest daily builds:
https://builder.blender.org/download/
david law (Ponlets) added a comment.Jul 10 2019, 1:33 PM
i am using the steam version of blender if that helps any but that should not matter
david law (Ponlets) added a comment.Jul 10 2019, 1:37 PM
OK so why does it work in the new version with blender 2.79 daily build but not in my current version as i have the exact same version of rigify as this one
i just have a few addons like the SFM import addon and the make human addon installed as well as FLIP fluids
Brecht Van Lommel (brecht) changed the task status from Unknown Status to Unknown Status.Jul 10 2019, 2:04 PM
I don't know the cause of the problem you have. But whatever it was, it appears to be fixed in the latest build which means it will be fixed in the next release and there is nothing for us left to do here.
david law (Ponlets) added a comment.Jul 10 2019, 2:06 PM
well i am still re doing the rig in the new one as i have to double check and will get back to you if the new rig works like the test one where all i did was spawn it
i am moving the bones again in the new rig to the proper places without changing parenting order or properties just location and rotation i will get back to you if it works or not
david law (Ponlets) added a comment.Jul 10 2019, 2:17 PM
ok so i got it to work so yea its something to do with that version of blender tho i wish rigify was more robust
david law (Ponlets) added a comment.Jul 10 2019, 2:37 PM
ok so when i add bones to the rig in any way or change a simple parenting arraingment it breaks it completely
all i did was add a few new bones to the chest and to the feet and redo the face to better fit the character by changing and disconnecting a few bones
WHY CANT IT JUST WORK
Sybren A. Stüvel (sybren) mentioned this in T66664: Rigify is broken .Jul 10 2019, 3:15 PM
Sybren A. Stüvel (sybren) added a subscriber: Sybren A. Stüvel (sybren).
@david law (Ponlets) This is not a user support forum, it is a bug tracker for Blender developers. Since the bug has already been fixed we cannot do anything else.
david law (Ponlets) added a comment.Jul 10 2019, 3:33 PM
how is the screen cap i sent signs its been fixed
the base meta rig works fine but if one adds a few new bones it breaks
it works if you remove bones but not if one adds bones
so it should work both ways and therefore is not fixed
Sybren A. Stüvel (sybren) added a comment.Jul 10 2019, 3:36 PM
The screen cap you show is from an old version of Blender. Fixes don't magically appear in old versions of Blender. The new version will be released soon (hopefully next week), and before that you can test with daily builds from https://builder.blender.org/download/
david law (Ponlets) added a comment.EditedJul 10 2019, 3:37 PM
the screen cap with the red lettering with the info window open is the latest daily build with no third party addons
david law (Ponlets) added a comment.Jul 10 2019, 3:56 PM
this is the latest daily build for 2.79 and its not working and i cant verify if the rig systems are stronger and smarter in 2.8 but the other issue is that they all changed the hot keys and other bits in 2.8 making it like one has to restart again with the education nulifying alot of udemy classes i have
Sybren A. Stüvel (sybren) added a comment.Jul 10 2019, 4:06 PM
All the development is focused on 2.80. We simply don't have the people to keep working on older releases too.
