Maniphest T66708
Sun shines thru solid Material on Edges
Closed, Archived
Sebastian Parborg (zeddb)
Rudolf Schörger (Rudolf.L.S)
Jul 11 2019, 3:47 PM
  • BF Blender
Cătălin George Feștilă (mythcat)
Philipp Oeser (lichtwerk)
Hallo
This is a Cube as Room with a Door and a Lamp. The Sun outside can shine thru some Edges of the solid Material.
PC: Windows 7 SP 1 64Bit
CPU: Intel i7-6700K 4GHz
Mem: 32GB (16GB)
Grafic: NVIDIA GeForce GTX 1060 6GB
Disk: Intens SSD SataIII 223GB NTFS
Rudolf Schörger (Rudolf.L.S) created this task.Jul 11 2019, 3:47 PM
Brecht Van Lommel (brecht) added a project: BF Blender.Jul 11 2019, 4:07 PM
Sebastian Parborg (zeddb) changed the task status from Unknown Status to Unknown Status.Jul 11 2019, 4:13 PM
Sebastian Parborg (zeddb) claimed this task.
Sebastian Parborg (zeddb) added a subscriber: Sebastian Parborg (zeddb).
This is a known limitation of the shadowing method.
Philipp Oeser (lichtwerk) added a subscriber: Philipp Oeser (lichtwerk).Jul 11 2019, 4:23 PM
Practical solution (to work around the limitation):
  • increase the suns shadow clip end to 50m (will get rid of the artifacts on the right side)
  • decrease the suns shadow softness to zero
  • increase the suns shadow exponent to something really high (e.g. 1000)
  • put a solidify modifier on the walls (can be negative/outwards so it doesnt change your framing, e.g. -0.03, preferably with "even thickness" turned ON)
Philipp Oeser (lichtwerk) added a subscriber: Cătălin George Feștilă (mythcat).
