Maniphest T66745
Eevee rendered viewport asserts if a sunlights shadow 'clip end' is set lower than 'clip start'
Closed, ResolvedBUG
Clément Foucault (fclem)
Philipp Oeser (lichtwerk)
Jul 12 2019, 10:34 AM
  • BF Blender
  • EEVEE & Viewport
Operating system: fedora 30, 5.1.16-300.fc30.x86_64
Graphics card: nvidia 970m, 430.26 drivers
Broken: 7ad21c3876c2453f11fd509a0157639d615567fc, master, 2019-07-11
  • open file
  • set viewport to rendered
  • on the selected sun light, in the Properties Editor > Light > Shadow, set End to 4m (Clip Start is 5m -- anything below 5m should assert...)
BLI_assert failed: /blender/source/blender/draw/intern/draw_manager_data.c:1262, draw_view_matrix_state_update(), at 'is_negative_m4(viewmat) == !is_negative_m4(winmat)'
backtrace
1  raise                                                  0x7ffff1b5be75
2  abort                                                  0x7ffff1b46895
3  draw_view_matrix_state_update draw_manager_data.c 1262 0x28edf1c
4  DRW_view_update               draw_manager_data.c 1349 0x28ee393
5  DRW_view_create               draw_manager_data.c 1296 0x28ee100
6  eevee_ensure_cascade_views    eevee_lights.c      1327 0x29242b8
7  EEVEE_draw_shadows            eevee_lights.c      1496 0x2924c28
8  eevee_draw_background         eevee_engine.c      226  0x2915ff2
9  drw_engines_draw_background   draw_manager.c      1163 0x28e5121
10 DRW_draw_render_loop_ex       draw_manager.c      1653 0x28e64bc
11 DRW_draw_view                 draw_manager.c      1544 0x28e5fa0
12 view3d_draw_view              view3d_draw.c       1459 0x2dff354
13 view3d_main_region_draw       view3d_draw.c       1483 0x2dff3f9
14 ED_region_do_draw             area.c              567  0x2ebe719
15 wm_draw_window_offscreen      wm_draw.c           616  0x23c6497
16 wm_draw_window                wm_draw.c           752  0x23c6a16
17 wm_draw_update                wm_draw.c           934  0x23c6fe2
18 WM_main                       wm.c                423  0x23c2ff2
19 main                          creator.c           500  0x1d7e266
Related Objects
Mentioned In
T67052: Camera perspective, corrupt 3D view in one workspace tab.
Mentioned Here
rB7ad21c3876c2: Fix T66604: Cycles bake crash on specific scene with volume
Philipp Oeser (lichtwerk) created this task.Jul 12 2019, 10:34 AM
Philipp Oeser (lichtwerk) assigned this task to Clément Foucault (fclem).Jul 12 2019, 10:39 AM
Philipp Oeser (lichtwerk) lowered the priority of this task from 90 to 50.
Philipp Oeser (lichtwerk) added a project: Eevee.
Philipp Oeser (lichtwerk) added a subscriber: Clément Foucault (fclem).
@Clément Foucault (fclem): not sure if this is rather harmless? (release builds seems to survive, but this sounds as if it might have unwanted consequences...)
possible solutions:
  • clamp this in code
  • let RNA handle start/end similar to what is done for scene frame_start, frame_end (in that: setting end < start will decrement start as well; setting start > end will increment end as well...)
feel free to throw back at me, I think I could do both...
Clément Foucault (fclem) reassigned this task from Clément Foucault (fclem) to Philipp Oeser (lichtwerk).Jul 12 2019, 10:47 AM
Yes you can do both.
Brecht Van Lommel (brecht) lowered the priority of this task from 50 to Low.Jul 14 2019, 7:25 PM
Dalai Felinto (dfelinto) removed Philipp Oeser (lichtwerk) as the assignee of this task.Dec 23 2019, 4:33 PM
Dalai Felinto (dfelinto) added a project: Tracker Curfew.
Clément Foucault (fclem) closed this task as Resolved.Jan 23 2020, 2:56 PM
Clément Foucault (fclem) claimed this task.
Clément Foucault (fclem) removed a project: Tracker Curfew.
Clément Foucault (fclem) changed the subtype of this task from "Report" to "Bug".
Sun shadows don't have clipstart/end anymore. The shadow bounds are computed automatically.
Clément Foucault (fclem) edited projects, added EEVEE & Viewport; removed Eevee.Jun 19 2020, 11:26 PM
