Maniphest T66831
When adding new mesh i can´t edit it.
Closed, Archived
Brecht Van Lommel (brecht)
Lautaro Iglesias (Lautaro.igl)
Jul 13 2019, 2:21 AM
  • BF Blender
Nahuel Belich (belich)
Graphics card: GeForce GTX 980 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 411.70
Broken: version: 2.80 (sub 74), branch: master, commit date: 2019-07-11 13:50, hash: rB06312c6d2db8
When i add a new mesh to the scene, i can't use the pop up menu. When i click on it, it close. Then, when i press ctrl + Z nothing happens or the program crash.
Add a new cylinder and try to reduce its vertices.
Lautaro Iglesias (Lautaro.igl) created this task.Jul 13 2019, 2:21 AM
Lautaro Iglesias (Lautaro.igl) renamed this task from When adding new meshn i can´t edit it. to When adding new mesh i can´t edit it..Jul 13 2019, 2:28 AM
Nahuel Belich (belich) added a subscriber: Nahuel Belich (belich).Jul 13 2019, 2:40 AM
i have a very similar cpu rig and works fine here, are u using any add-on? did you try loading factory settings?
Lautaro Iglesias (Lautaro.igl) added a comment.Jul 13 2019, 3:57 PM
If I use the default settings, the error does not happen, however, I am not using any strange add-on. There is something that is causing me problems.
Here is a video of the problem.
Brecht Van Lommel (brecht) changed the task status from Unknown Status to Unknown Status.Jul 14 2019, 7:20 PM
Brecht Van Lommel (brecht) added a subscriber: Brecht Van Lommel (brecht).
This can happen when Preference > System has Global undo disabled, usually due to a buggy add-on. Enabling it again should fix the problem.
