Maniphest T66872
Changing the Colorspace settings of a Movieclip is not properly updating Camera Background Images
Closed, Resolved
Sergey Sharybin (sergey)
Sebastian Koenig (sebastian_k)
Jul 13 2019, 5:48 PM
  • BF Blender
  • Motion Tracking
Sebastian Parborg (zeddb)
Operating system: Linux-4.4.0-151-generic-x86_64-with-debian-stretch-sid 64 Bits
Graphics card: GeForce GTX 1080/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 430.26
Broken: version: 2.80 (sub 74), branch: master, commit date: 2019-07-12 17:50, hash: rBe3c586e262dd
Changing the colorspace of Camera Background Images (in this case Movieclip) is not properly updating the display in the 3d viewport.
For example I load a sequence of EXR images in the Clip Editor and set that clip as source for Camera Background images.
If I now change the color space in the colorspace dropdown menu in the Camera Background Images panel, the colors of the clip in the clip editor change accordingly, but the colors of the background images in the 3d viewport stay the same.
Let's take this file as an example:
Inititally the color space of the clip is set to Linear.
Now change the colorspace to e.g. Linear Aces (not that this would make much sense in this case, but as a demo).
The colors of the clip change, the colors of the image in 3d viewport do not.
However:
If you now press the button "Render Undistorted" in the camera background images panel, the colors in 3d view update.
If you disable the button again, the colors go back to the look they had before. I assume the 2 versions are cached somehow.
The thing is, if you now change the colorspace to Raw for instance, pressing "Render Undistorted" does not update the display of colors anymore.
So there is no reliable way to adjust the colorspace of background images.
What I assume would happen is that as soon as I change the colorspace, the internal cache is deleted and the view updated.
Revisions and Commits
rB Blender
Sebastian Koenig (sebastian_k) created this task.Jul 13 2019, 5:48 PM
Sebastian Koenig (sebastian_k) added a project: Motion Tracking.
Sebastian Parborg (zeddb) assigned this task to Sergey Sharybin (sergey).Jul 18 2019, 2:07 PM
Sebastian Parborg (zeddb) added subscribers: Sergey Sharybin (sergey), Sebastian Parborg (zeddb).
@Sergey Sharybin (sergey) I'm guessing this an update event is missing?
Sergey Sharybin (sergey) mentioned this in T67736: Delay in Compositor on frame change.Jul 26 2019, 4:16 PM
Sergey Sharybin (sergey) merged a task: T67736: Delay in Compositor on frame change.
NOTE: The issue is not limited to the color management, and actual solution is to make movie clip cache shared across compositor, render engines, editors and so on (currently those are decoupled).
Sergey Sharybin (sergey) changed the task status from Unknown Status to Resolved by committing rB2cce65de9695: Fix T66872: Changing clip color space does not update background images.Jul 28 2019, 1:27 PM
Sergey Sharybin (sergey) added a commit: rB2cce65de9695: Fix T66872: Changing clip color space does not update background images.
