Maniphest T66924
bpy.ops.preferences.addon_enable() only checks for changes in __init__.py; Problem for multi-file add-ons
Closed, Archived
Sybren A. Stüvel (sybren)
Iemand Iets (NumesSanguis)
Jul 14 2019, 5:24 PM
  • Add-ons (Community)
  • BF Blender: Regressions
Antonio Vazquez (antoniov)
gecko man (geckoman)
Joseph Davies (Deledrius)
yonghao lv (Atticuslv)
Symptoms
When you're developing an add-on existing out of multiple files on a disk, you want to reload your add-on many times to include the changes you made.
This works fine when you make a modification in __init__.py and call bpy.ops.preferences.addon_enable(module='your_module'), as you will see: "module changed on disk: 'path/to/file.py' reloading...".
However, if you make a change in another module, e.g. your_module_props.py, and call addon_enable(), nothing is triggered. You will only see {'FINISHED'}.
If you afterwards make a change to __init__.py, the previous changes you made to your_module_props.py are seen by Blender this time when you call addon_enable().
Likely culprit
I believe the culprit is here: https://developer.blender.org/diffusion/B/browse/master/release/scripts/modules/addon_utils.py$325
mtime_orig = getattr(mod, "__time__", 0)
mtime_new = os.path.getmtime(mod.__file__)  # only checks __init__.py
if mtime_orig != mtime_new:
These lines of code only check if the main file (__init__.py) has changed.
Possible solutions
One of the following:
  1. Extend the check to check if any (Python) file of an add-on has changed.
  2. Remove the check if files changed, and always trigger the reload.
Importance
Any medium/large add-on that follows proper code conventions to prevent spaghetti code will use multiple files. This limited check to only __init__.py severely slows down app development, as we cannot do a quick reload. Instead we have to make a minimal change to __init__.py to trigger the reload, or restart Blender every time we have made a code modification.
Revisions and Commits
rB Blender
D5470
Iemand Iets (NumesSanguis) created this task.Jul 14 2019, 5:24 PM
Iemand Iets (NumesSanguis) added a comment.Jul 14 2019, 6:37 PM
To test if the check if mtime_orig != mtime_new: is indeed the problem, I made an operator (simplified version of the original addon_enable(): developer.blender.org/diffusion/B/browse/master/release/scripts/modules/addon_utils.py$327) with that removed:
class OBJECT_OT_reload_module(bpy.types.Operator):
    bl_idname = "object.reload_module"
    bl_label = "Reload specified module"
    bl_options = {'REGISTER'}
    def execute(self, context):
        print("Hello")
        import importlib
        import sys
        module_name = "your_module"
        mod = sys.modules.get(module_name)
        mod.__addon_enabled__ = False
        try:
            importlib.reload(mod)
        except Exception as ex:
            # handle_error(ex)
            print(f"Failed: {ex}")
            del sys.modules[module_name]
            return None
        mod.register()
        # * OK loaded successfully! *
        mod.__addon_enabled__ = True
        return {'FINISHED'}
and indeed, the add-on properly reloads now.
So I would suggest solution 2 in the main post.
Sybren A. Stüvel (sybren) changed the task status from Unknown Status to Unknown Status.Jul 16 2019, 1:54 PM
Sybren A. Stüvel (sybren) claimed this task.
Sybren A. Stüvel (sybren) added a subscriber: Sybren A. Stüvel (sybren).
Fortunately, this is not as big an issue as you describe. The code you linked is only used when enabling an add-on; the issue you describe seems to assume the way to reload an add-on is to disable and enable it.
Reloading your add-on can be done via the bpy.ops.script.reload() operator which was bound to F8 in Blender 2.79; it's now available with the F3 menu (search for 'reload scripts') and you can create your own keyboard binding if you want. Multi-file addons need reloading support, which is quite easy to do; see this slide and the following slides or watch my Blender Conference 2016 workshop on the subject.
Iemand Iets (NumesSanguis) added a comment.Jul 21 2019, 4:06 PM
Thank you @Sybren A. Stüvel (sybren) , bpy.ops.script.reload() indeed reloads all add-ons. I had if "bpy" in locals(): check to reload add-ons, but that wasn't triggered by my code, because __init__.py didn't change.
While luckily indeed a smaller issue than I assumed, I think it's not a solved one.
  1. When asked at blender.chat Python API channel: https://blender.chat/channel/python?msg=fGEyJtjNZqfpApxQ5 , none of the multiple people who responded pointed me to bpy.ops.script.reload() instead of bpy.ops.preferences.addon_enable(module='your_module') I would assume the most knowledgeable Python programmers are active here, and therefore it seems bpy.ops.script.reload() is not common knowledge. This is more a documentation issue, so I created an issue about this here: https://developer.blender.org/T67387
  2. bpy.ops.script.reload() reloads ALL add-ons. If one of these add-ons is producing a error / warning, it will pollute the output/logs for the add-on you're actually try to develop. Also, if (multiple) non-relevant add-on(s) are slow at initializing, it will slow down the development process. Possible solutions I could think of:
    1. Allow for an argument to bpy.ops.script.reload(module_name=None), and only reload all when either None or no argument is passed.
    2. Make bpy.ops.preferences.addon_enable(module='your_module') intended for reloading specific add-ons by remove / extend the check if only __init__.py file changed.
Campbell Barton (campbellbarton) added a subscriber: Campbell Barton (campbellbarton).Jul 21 2019, 4:29 PM
For development, you can:
import importlib
importlib.reload(your_addon_name)
Checking the date on the init file isn't meant to be a comprehensive check of the entire package.
Sybren A. Stüvel (sybren) added a comment.Jul 22 2019, 11:24 AM
Not all of them, and not all the time. Just search the Python API documentation for "reload script" and you'll find the bpy.ops.script.reload() operator. Granted, it's not documented very well.
Well, if you keep multiple non-relevant add-ons enabled while you're developing, I don't think this is an issue with reloading. I think it's an issue between keyboard & chair.
import importlib
You could even add this code to an operator in your add-on and bind it to a menu item or button, then it's literally a one-click reload for only your add-on.
gecko man (geckoman) added a subscriber: gecko man (geckoman).Jul 22 2019, 9:02 PM
I have created a workaround to this problem.
Example __init__.py:
import importlib, sys # required
# reloads class' parent module and returns updated class
def reload_class(c):
	mod = sys.modules.get(c.__module__)
	return mod.__dict__[c.__name__]
# imports to be updated
from . somefile import someclass
from . import somemodule
someclass = reload_class(someclass) # reload imported class
importlib.reload(somemodule) # reload imported module
someclass and somemodule will stay up-to-date when reloading addon with bpy.ops.preferences.addon_enable() and with bpy.ops.script.reload().
Sybren A. Stüvel (sybren) added a comment.Jul 22 2019, 11:16 PM
Don't use the from X import Y syntax to import individual classes, that'll make reloading more cumbersome (as you've seen). If you just import (sub)modules you avoid the need for that reload_class() function.
Iemand Iets (NumesSanguis) added a comment.EditedJul 25 2019, 4:14 PM
That's good advice. I've gotten so used to just Googling things and usually finding the answer on stackoverflow, I forgot about direct searching.
For some reason Google doesn't index the Blender documentation, which would probably trouble more newcomers to Blender.
While in most case you'd be right, there are people who develop add-ons, that rely on / add functionality to add-ons of others. It is not always possible to merge this into 2 add-ons.
You could say, you could help speed-up that add-on, but some add-on creators are satisfied with their solution of whatever reason they have to not accept your contribution.
Also, it's possible that the add-on you rely on is good, but only requires a long initialization time (e.g. setup TCP connections to programs outside Blender, not so weird if you want to visualize data from a Robot).
The situation at the moment is:
  • A function that can reload single add-ons, you're not supposed to use (bpy.ops.preferences.addon_enable(module='your_module'))
  • A function that can only reload all add-ons (bpy.ops.script.reload())
Is it a huge problem? Not really. However, to me it feels like poor design that you can't just reload 1 add-on. Even if in most cases reloading all add-ons won't be much of a slowdown.
Would you say it makes sense if there is a function that can reload a (list of) specific add-ons? Given it's not too much effort to implement.
p.s. Could someone point me to the reload script?
p.p.s
Asked for referencing the code by making the function names on the documentation page clickable: https://developer.blender.org/T67674
import importlib
Yeah, I did this. Is slightly less smooth if you're bugs are in the registering of the modules, which breaks the unloading, although that could have been because of me using addon_enable :')
Antonio Vazquez (antoniov) changed the task status from Unknown Status to Resolved by committing rBee4ec69b2804: Fix T66924 : Move GPencil Modifiers evaluation to Depsgraph.Aug 23 2019, 11:14 PM
Antonio Vazquez (antoniov) added a commit: rBee4ec69b2804: Fix T66924 : Move GPencil Modifiers evaluation to Depsgraph.
Antonio Vazquez (antoniov) changed the task status from Resolved to Unknown Status.Aug 23 2019, 11:27 PM
Antonio Vazquez (antoniov) added a subscriber: Antonio Vazquez (antoniov).
Sorry, closed by error.
Antonio Vazquez (antoniov) changed the task status from Unknown Status to Unknown Status.Aug 23 2019, 11:28 PM
Antonio Vazquez (antoniov) mentioned this in rBee4ec69b2804: Fix T66924 : Move GPencil Modifiers evaluation to Depsgraph.
Joseph Davies (Deledrius) added a subscriber: Joseph Davies (Deledrius).May 28 2020, 11:41 AM
yonghao lv (Atticuslv) added a subscriber: yonghao lv (Atticuslv).May 20 2022, 10:12 AM
Recently , I notice that use reload() will destory the socket connection(when it became complex) on win. (win 10054 error)
