Can't add Workspace from general section.
To reproduce - open Blender 2.8. Add Workspace - this from first part in General section not working (see attachment). The others are fine.
Blender 2.8 RC1, Windows 8.1
| Brecht Van Lommel (brecht) |
| Luke (winhelp) | |
| Jul 14 2019, 10:04 PM |
| Gavin Scott (Zoot) |
| Luke (winhelp) |
| Sebastian Parborg (zeddb) |
| rB Blender | |||
| D5270 | rB1f1d30295004 Fix T66940, T67005, T60651: append workspace from old startup file fails | ||
Those look like the 2.79 Spaces which get converted to Workspaces when you open a 2.79 file in 2.80, but I've not seen them end up in the New Workspace menu like that before, so the question is how they got in there.
Did you open a .blend file that led to this condition, in which case can you share that .blend file? Or is this what you see with a File->New document or a fresh startup of Blender, in which case do you know if you did a File->Defaults->Save Startup FIle at some point?
Ok, I can reproduce the menu look by opening a 2.79 file and then doing File->Defaults->Save Startup File. All the existing Workspaces get added to the Add Workspace menu as shown here when you start Blender afterward:
It makes sense that it might be intended to work this way. I'm not sure how many people have actually tried this though.
What happens when you try to Add these Workspaces? Does it do nothing, or do you get an error, etc? It generally seems to work for me.
