Maniphest T67038
Alembic cache induces flickering and change of position on hair driven by that surfaces connected to it.
Closed, Duplicate
None
carlos puebla (negativecitizen)
Jul 16 2019, 6:39 AM
  • BF Blender
  • Alembic
Philipp Oeser (lichtwerk)
Graphics card: GeForce GTX 1060 6GB/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 430.86
Broken: version: 2.80 (sub 74), branch: master, commit date: 2019-07-11 13:50, hash: rB06312c6d2db8
Hair changes every frame when is driven by a surface using an alembic cache (cache sequencer ). The position of every strand is lost, not a big changes but subtle .When i change to an mdd cache all works as expected .constant position in hairs, no flicker .
Open scene with an object with hair, create a Mesh Sequence Cache modifier on it to drive it , connect it to the proper abc file , and the right object path .Render a few frames.Result flicker
the same procedure changing to a Mesh Cache( with .mdd ) modifier render a few frames , works fine.
In viewport al works fine in both ways .The hairs doesn't varies his position.
note.The zip file contains also cache files in relative path way
carlos puebla (negativecitizen) created this task.Jul 16 2019, 6:39 AM
Philipp Oeser (lichtwerk) added a project: Alembic.Jul 16 2019, 8:40 AM
It is still rendering, but I assume this is the same as T63534
Philipp Oeser (lichtwerk) added a comment.Jul 16 2019, 11:47 AM
Looks like these are the same issues as in T63534, I will merge this report into the existing one...
