Operating system: Windows 10
Graphics card: GTX 1080 Ti
Broken: 2.80 Release Candidate 1
Rotation values inputted after hitting "r" and then hitting an axis value like "x" are wrong.
If I select an Object and hit "r" then "x" then "720" then "return", the X-rotation will be set to 0.00002d
Or if i enter rx359 the x-rotation will be set to -1.
If I input them in the n-panel it works fine, if I input them in the properties panel it works fine, too. And if I use the widget to rotate the cube two times in that axis and let go it's also 720 degrees. The wrong values appear just when inputting them the way described above.
I think this should be consistent all over the place and it really makes no sense that it rotates my cube -1 on the x-axis when i clearly wanted it to rotate 359 degrees in the other direction on that axis...
Select an Object and hit "r" then "x" then "720" then "return", the X-rotatioin will be set to 0.00002d
Or enter rx359 the x-rotation will be set to -1.
