Maniphest T67151
Blender 2.80 Real-time rendering is not working !
Closed, Archived
Demeter Dzadik (Mets)
joaovicpe
Jul 18 2019, 12:19 AM
  • BF Blender
Germano Cavalcante (mano-wii)
joaovicpe
An error is occurring in the real-time rendering of Blender 2.80, every time I try to render, the program crashes. Blender 2.80 is not optimized for low computers, my graphical memory is 64MB and the RAM is 4GB, even though it is very little, the program worked 100% correctly in previous versions. Thanks for listening..
joaovicpe created this task.Jul 18 2019, 12:19 AM
Demeter Dzadik (Mets) changed the task status from Unknown Status to Archived.Jul 18 2019, 12:27 AM
Demeter Dzadik (Mets) claimed this task.
Demeter Dzadik (Mets) added a subscriber: Demeter Dzadik (Mets).
Please use the bug report template and fill out all the information, the devs can't do much with this...
Germano Cavalcante (mano-wii) added a subscriber: Germano Cavalcante (mano-wii).Jul 18 2019, 12:30 AM
Performance should not be much worse compared to previous versions.
If you are observing too much slowness and crashes this is a bug and needs to be investigated.
But as @Demeter Dzadik (Mets) said there is not much to do without information like Operating System and Graphics Card.
joaovicpe renamed this task from Blender 2.80 is crashing a lot !! to Blender 2.80 Real-time rendering is not working !.Jul 18 2019, 12:39 AM
joaovicpe changed the task status from Archived to Unknown Status.
joaovicpe updated the task description.
Demeter Dzadik (Mets) changed the task status from Unknown Status to Unknown Status.EditedJul 18 2019, 12:45 AM
Grass grows, birds fly, and software system requirements increase over time, as is the case for Blender. 2.80's system requirements are increased compared to 2.79. You can find them here. See if your graphics card(which is still a mystery) is newer than the minimum requirement. If it isn't, then nothing can be done. If it is, please submit a new report where you fill out the template.
joaovicpe added a comment.Jul 18 2019, 12:47 AM
Thank you, I never saw the requirements before. I am Sad
joaovicpe added a comment.Jul 18 2019, 12:51 AM
Unfortunately this is another program that I will have to stop using, I will migrate to 3Ds Max.
