Maniphest T67203
Shortcut to "Toggle Maximize Area" is listed in the menu but does not work as labeled.
Closed, Archived
hudson barkley (snuq)
Jul 19 2019, 2:55 AM
  • BF Blender
Gavin Scott (Zoot)
Iain McGregor (ijay99)
Peter Fog (tintwotin)
Philipp Oeser (lichtwerk)
Yevgeny Makarov (jenkm)
Broken: 2.80
Now that the ctrl-up shortcut to maximize the area is gone, this brings up the issue that the ctrl-space is already used in the console for auto-complete, and thus there is no longer a shortcut to maximize the console area.
hudson barkley (snuq) created this task.Jul 19 2019, 2:55 AM
Gavin Scott (Zoot) added a subscriber: Gavin Scott (Zoot).EditedJul 19 2019, 4:24 AM
Have you tried CTRL-ALT-SPACE?
Both CTRL-SPACE and CTRL-ALT-SPACE are defined in the default keymap for this function. CTRL-ALT-SPACE seems to work everywhere for me.
Gavin Scott (Zoot) lowered the priority of this task from 90 to 30.Jul 19 2019, 5:27 AM
hudson barkley (snuq) added a comment.Jul 19 2019, 6:30 AM
Ah yeah, ctrl-alt-space works. I guess the menu in the console area should be changed to reflect this? right now it lists ctrl-space as the shortcut.
Gavin Scott (Zoot) raised the priority of this task from 30 to 90.Jul 19 2019, 7:07 AM
Yes, that's a valid point. Below is what the header context menu looks like for reference. Not sure if it could easily be smart enough to show the ALT version only if there's an overriding conflicting keymap. So I think this really isn't a bug so much as an enhancement request to make the automatic keybind display smarter. I'll leave it for someone else to decide if it's worthy of keeping as a bug.
(If the menu display bothers you, you can go into the keymap and use the search function to look for functions with toggle in the name, and that will put the two key bindings under Screen at the top. Open them both up and toggle the ALT selector button in each one which will make the CTRL-ALT-SPACE version listed first, and then it will start showing up as the shortcut (in ALL your headers).
Campbell Barton (campbellbarton) renamed this task from Shortcut to "Toggle Maximize Area" in console is broken to Shortcut to "Toggle Maximize Area" is listed in the menu but does not work as labeled..Jul 19 2019, 9:26 AM
Campbell Barton (campbellbarton) changed the task status from Unknown Status to Unknown Status.Jul 19 2019, 9:40 AM
Campbell Barton (campbellbarton) claimed this task.
Campbell Barton (campbellbarton) added a subscriber: Campbell Barton (campbellbarton).
Added TODO T67213, closing.
Campbell Barton (campbellbarton) mentioned this in T67213: Add a text editor indent-or-auto-complete operator.Jul 19 2019, 9:40 AM
Philipp Oeser (lichtwerk) added subscribers: Iain McGregor (ijay99), Philipp Oeser (lichtwerk), Yevgeny Makarov (jenkm), Peter Fog (tintwotin).
