Maniphest T67222
Instacrash on .blend open
Closed, Archived
Sebastian Parborg (zeddb)
Ilja Razinkov (IPv6)
Jul 19 2019, 12:51 PM
  • BF Blender
dark999 (dark999)
Gavin Scott (Zoot)
Philipp Oeser (lichtwerk)
Operating system: MacOs Mojave 10.14.5
Broken: 2.79, build 2019-06-27 10:41
I was experimenting with driver that return current frame number into input value of node... and managed to save blend file, that can not be opened anymore - now Blender crashes right after this blend file is loaded. See attachment
Ilja Razinkov (IPv6) created this task.Jul 19 2019, 12:51 PM
Brecht Van Lommel (brecht) updated the task description.Jul 19 2019, 12:58 PM
Philipp Oeser (lichtwerk) added a subscriber: Philipp Oeser (lichtwerk).Jul 19 2019, 1:22 PM
No crash opening that file in 2.8 here.
Get a crash in 2.79 though... need a Debug build to check further... I guess that has low priority though (since we are not really chasing 2.79 only bugs anymore -- at least with lower priority...)
note1: file is saved in local view [not that this should cause a problem, just saying because nothing visible when opening that file...]
note 2: 2.8 also complains about the driver expression
Error in Driver: The following Python expression failed:
	'#frame'
note 3: There is a missing linked library, please also upload that file here...
Ilja Razinkov (IPv6) added a comment.Jul 19 2019, 1:32 PM
I see, understand regarding now priority, etc. Great that 2.8 handles this well :)
Linked libraries are not related to crash (they are plain material holders), problem arised directly after this exact driver was added for testing purposes
Gavin Scott (Zoot) added a subscriber: Gavin Scott (Zoot).Jul 19 2019, 6:01 PM
Actually it appears to open fine in 2.79a, it's just 2.79 experimental that has an issue.
dark999 (dark999) added a subscriber: dark999 (dark999).Jul 19 2019, 7:00 PM
@Gavin Scott (Zoot) lastest Blender satble is 2.79B untill next week 2.80 release
Sebastian Parborg (zeddb) changed the task status from Unknown Status to Unknown Status.Jul 31 2019, 10:55 AM
Sebastian Parborg (zeddb) claimed this task.
Sebastian Parborg (zeddb) added a subscriber: Sebastian Parborg (zeddb).
We do not fix bugs in the 2.79 release anymore.
