Maniphest T67300
scale gizmo 1d
Closed, Archived
Germano Cavalcante (mano-wii)
Jorge Jiménez (Arje3d)
Jul 20 2019, 9:16 AM
  • BF Blender
ronan ducluzeau (zeauro)
Operating system: windows
Graphics card: nvidia geforce gtx 770m
ver 2.8 and the 2.79 also
the scale gizmo dont work in 1d if you previously rotated the cube aleatory
rotate the default cube in 3 axis and then try to scale the cube in one direction with the scale gizmo, the cube scales in 3 direction
Jorge Jiménez (Arje3d) created this task.Jul 20 2019, 9:16 AM
ronan ducluzeau (zeauro) added a subscriber: ronan ducluzeau (zeauro).EditedJul 20 2019, 5:18 PM
Unfortunately, problem seems to be worst than that.
Scale operator does not work correctly with shortcut keys either.
Scale Cage has also an unpredictable behavior.
Sometimes, it scales badly, transforming several dimensions instead of one.
Sometimes, it translates object instead of scaling it.
Germano Cavalcante (mano-wii) changed the task status from Unknown Status to Unknown Status.Jul 22 2019, 3:44 PM
Germano Cavalcante (mano-wii) claimed this task.
Germano Cavalcante (mano-wii) added a subscriber: Germano Cavalcante (mano-wii).
It's by designed in order to keep consistent the three scale values by object.
You can work around this by parenting the object to an empty that is aligned with the global axis and scale the empty instead of the object.
