Maniphest T67330
Eevee render always crashes on my Intel integrated graphics.
Closed, Archived
Bastien Montagne (mont29)
Maruf (Maruf007)
Jul 20 2019, 4:40 PM
  • BF Blender
Alessio Monti di Sopra (a.monti)
Caden Mitchell (CadenMitchell)
Gabriel Borges (KesaiArts01)
Maruf (Maruf007)
Sovann (sovann9000)
Operating system: Win 7 64 bit
Graphics card: Intel HD 4000
Broken: (example: 2.80, edbf15d3c044, master, 2018-11-28, as found on the splash screen)
whenever I turn on Eevee render, 80% of time it crashes , also it lags heavily when I use color pallet for material colors.
and this 2.8 runs slower than 2.79 on my laptop.
Maruf (Maruf007) created this task.Jul 20 2019, 4:40 PM
Alessio Monti di Sopra (a.monti) lowered the priority of this task from 90 to 30.Jul 20 2019, 5:11 PM
Alessio Monti di Sopra (a.monti) added a subscriber: Alessio Monti di Sopra (a.monti).
Hi, the Blender version is missing from your report, are you using the second release candidate? There have been a couple of fixes regarding Intel GPUs.
Either ways, it would be really useful if you could post the exact version of your drivers; you can directly attach here the exported file you get from
Help > Save System Info inside Blender.
Caden Mitchell (CadenMitchell) added a subscriber: Caden Mitchell (CadenMitchell).Jul 20 2019, 6:19 PM
@Alessio Monti di Sopra (a.monti) i've experienced similar issues. My report was more complete but same issue. It renders a limited frame range then fails to render the rest correctly. T67304
Gabriel Borges (KesaiArts01) added a subscriber: Gabriel Borges (KesaiArts01).Jul 20 2019, 11:49 PM
Same here
Alessio Monti di Sopra (a.monti) added a comment.Jul 21 2019, 11:40 AM
@Caden Mitchell (CadenMitchell) doesn't seem that related to me, here Eevee doesn't even start plus the gpu is quite older. Both could be a driver issue, as many other reports have been in the past months, but we need the driver versions.
Bastien Montagne (mont29) changed the task status from Unknown Status to Archived.Jul 29 2019, 6:05 PM
Bastien Montagne (mont29) added a subscriber: Bastien Montagne (mont29).
Sovann (sovann9000) added a subscriber: Sovann (sovann9000).Sep 6 2020, 5:42 AM
It used to happened to my laptop too but try 2.9 it's working fine on intel graphic 4000 now.
