Maniphest T67344
Collada Import Skeleton animations Y and Z axis are swapped
Confirmed, NormalKNOWN ISSUE
None
Clinton Reese (clintonman)
Jul 20 2019, 7:57 PM
  • BF Blender
  • Collada
  • Import/Export
  • Pipeline, Assets & I/O
Alexander Gavrilov (angavrilov)
Gaia Clary (gaiaclary)
Germano Cavalcante (mano-wii)
Joshua Leung (aligorith)
Sybren A. Stüvel (sybren)
Graphics card: GeForce GTX 550 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 388.13
Broken: version: 2.80 (sub 74), branch: master, commit date: 2019-07-18 14:52, hash: rB38d4483c6a51
Import the attached Collada file.
Animation shows rotation in Z direction with a twisting motion.
The collada file has rotation in the Y direction which should appear as a bending motion.
Clinton Reese (clintonman) created this task.Jul 20 2019, 7:57 PM
Germano Cavalcante (mano-wii) updated the task description.Jul 23 2019, 1:36 PM
Germano Cavalcante (mano-wii) added subscribers: Gaia Clary (gaiaclary), Germano Cavalcante (mano-wii).Jul 23 2019, 1:40 PM
@Gaia Clary (gaiaclary), what do you think? A known limitation?
Gaia Clary (gaiaclary) lowered the priority of this task from 90 to Normal.Jul 23 2019, 3:40 PM
I am not sure if this is really an importer issue.
Here is what i did so far:
  • tested on Blender 2.79 with default settings and i found everything is working as expected
  • tested on Blender 2.79 with find chain nodes and autoconnect enabled. that works as well
  • tested on Blender 2.80 with default settings: bones animate wrong
  • tested on Blender 2.80 with find chain nodes and autoconnect enabled: that works
It can well be a change in the importer or a change in the animation system.
Any opinion from an animation expert developer ?
Germano Cavalcante (mano-wii) added subscribers: Joshua Leung (aligorith), Alexander Gavrilov (angavrilov), Sybren A. Stüvel (sybren).Jul 23 2019, 4:37 PM
Sybren A. Stüvel (sybren) added a comment.Aug 9 2019, 11:18 AM
AFAIK the animation system hasn't changed in such a way that would cause rotations to be stored in a different way.
I have zero experience with Collada, so I can't comment on the importer.
Dalai Felinto (dfelinto) added a project: Tracker Curfew.Dec 23 2019, 4:33 PM
Sybren A. Stüvel (sybren) added a project: Collada.Feb 6 2020, 5:47 PM
Germano Cavalcante (mano-wii) edited projects, added Pipeline, Assets & I/O, Import/Export; removed Tracker Curfew.Feb 6 2020, 7:02 PM
Germano Cavalcante (mano-wii) changed the subtype of this task from "Report" to "Known Issue".
Bastien Montagne (mont29) removed a project: Pipeline, Assets & I/O.Feb 13 2020, 9:37 PM
Bastien Montagne (mont29) added a project: Pipeline, Assets & I/O.Jun 11 2020, 5:24 PM
Bastien Montagne (mont29) moved this task from Backlog to Known Issues on the Pipeline, Assets & I/O board.Jun 11 2020, 6:08 PM
