Graphics card: GeForce GTX 1080 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 430.64
Broken: version: 2.80 (sub 74), branch: master, commit date: 2019-07-18 14:52, hash: rB38d4483c6a51
I have some more complex scenes where the node editor interactions are quite laggy even if the 3D viewport is not part of the layout at all. Simple things like dragging selection box or moving around nodes in viewport cause stutter and UI lag. Pretty much any mouse cursor interaction with node editor does.
- In a new .blend file, subdivide the default cube several times, so it has around 25k polygons
- Duplicate (not instantiate) this cube about 500 times
- Select about half (250) of the cubes, and parent them to one of the cubes
- Select other half of the cubes, and again, parent them to one another cube
- You should have two cubes each with around 249 children.
- Select one random cube, and assign a new material to it
- Open node editor and interact with the material.
- Notice the node editor interaction is very laggy
- Create a new cube, that is not parented to anything (not part of the complex hierarchy)
- Assign a new material to it
- Notice the node editor interaction is still extremely laggy
- Remove 3D view from the active workspace
Result: The sheer complexity of the scene causes node editor interaction to be very laggy, even when using node editor to interact with nodes which are not a direct part of the scene complexity (A new unique material on a new unique cube with a new unique mesh data block). Also, removing 3D viewport from the workspace layout does not help.
Expected: Node editor interaction remains smooth regardless of scene complexity
It appears that every single UI interaction such as mouse click in the node editor is evaluating a lot more data than it needs to.
