Maniphest T67441
User Interface (Hitbox mis-aligned)
Closed, Duplicate
None
Nawaf Al-Rawachy (NawafAl-Rawachy)
Jul 22 2019, 1:13 PM
  • BF Blender
Brecht Van Lommel (brecht)
Graphics card: GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 416.34
Broken: version: 2.80 (sub 74), branch: master, commit date: 2019-07-18 14:52, hash: rB38d4483c6a51
[The UI elements' hit box is off by about 20 or 30 pixels, hovering on the button does nothing, but hovering slightly lower than the button will highlight it, can cause problems as it presses a button other than what my cursor is hovering over]
[Not 100% Sure, but I was rendering in EVEE at a very high resolution which was making the compositor lag, then I switched to the layout tab and back to compositor tab quickly after I hit f12 to render]
Nawaf Al-Rawachy (NawafAl-Rawachy) renamed this task from User Interface (Hitbox misaligned to User Interface (Hitbox misaligned).Jul 22 2019, 1:13 PM
Nawaf Al-Rawachy (NawafAl-Rawachy) renamed this task from User Interface (Hitbox misaligned) to User Interface (Hitbox mis-aligned).
Nawaf Al-Rawachy (NawafAl-Rawachy) created this task.
Nawaf Al-Rawachy (NawafAl-Rawachy) updated the task description.
Brecht Van Lommel (brecht) lowered the priority of this task from 90 to 30.Jul 22 2019, 4:08 PM
Brecht Van Lommel (brecht) added a subscriber: Brecht Van Lommel (brecht).
We need exact steps to reproduce this issue, otherwise will be difficult to investigate.
Nawaf Al-Rawachy (NawafAl-Rawachy) added a comment.Jul 22 2019, 4:16 PM
Alright it happened again, seems to be happening when I render using the "Render Display Mode > New Window" with a resolution of higher than 7k
Bastien Montagne (mont29) raised the priority of this task from 30 to 80.Jul 29 2019, 5:57 PM
