Maniphest T67476
Image export is changing colors.
Closed, Archived
Brecht Van Lommel (brecht)
Dum kaka (DumKaka)
Jul 22 2019, 11:54 PM
  • BF Blender
Dum kaka (DumKaka)
Sebastian Parborg (zeddb)
Graphics card: GeForce GTX 1060 6GB/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 430.86
Broken: version: 2.80 (sub 74), branch: master, commit date: 2019-07-18 14:52, hash: rB38d4483c6a51
TL;DR image export is changing colors little bit.
Am i doing something wrong or Image export is not working correctly.
Check video for details.
thanks.
test with flat color.
https://youtu.be/iVHLbR9Csko
Dum kaka (DumKaka) created this task.Jul 22 2019, 11:54 PM
Dum kaka (DumKaka) updated the task description.
Brecht Van Lommel (brecht) changed the task status from Unknown Status to Unknown Status.Jul 23 2019, 4:49 PM
Brecht Van Lommel (brecht) added a subscriber: Brecht Van Lommel (brecht).
Filmic color management is enabled by default for compositor output, which will have this effect. You can change Render properties > Color Management > View Transform to Standard.
Dum kaka (DumKaka) added a comment.Jul 23 2019, 5:22 PM
could you check the video please? 0:07 - 0:17
Brecht Van Lommel (brecht) changed the task status from Unknown Status to Unknown Status.Jul 23 2019, 5:23 PM
Brecht Van Lommel (brecht) lowered the priority of this task from 90 to 30.
Please attach a .blend file to reproduce the issue then.
Dum kaka (DumKaka) added a comment.EditedJul 23 2019, 7:19 PM
hello,
steps are simple. all you need to do change export location and hit f12. Exported file needs to be check.
thank you.
Brecht Van Lommel (brecht) raised the priority of this task from 30 to 90.Aug 4 2019, 1:26 PM
Sebastian Parborg (zeddb) changed the task status from Unknown Status to Unknown Status.Aug 5 2019, 12:39 PM
Sebastian Parborg (zeddb) added a subscriber: Sebastian Parborg (zeddb).
You need to remove dithering (set it to 0) to not get these noise patterns in the output:
https://docs.blender.org/manual/en/latest/render/output/settings.html?highlight=dithering#dithering
It seemed to solve this for me at least. Let me know if this isn't the case for you.
