Maniphest T67854
Boolean Modifier Warps Objects
Closed, Resolved
Philipp Oeser (lichtwerk)
Aritra Dhar (adhar0919)
Jul 28 2019, 9:22 PM
  • BF Blender
Alex (SpectreFirst)
William Reynish (billreynish)
Windows 10 (Latest Update)
RTX 2060
Ryzen 5 2600
Blender 2.8
Applying the Boolean Modifer to an objects as in when putting one object through another with difference causes the object containing the Boolean to be slightly deformed.
The image shows how the room has been deformed after a boolean was applied on it to fit the windows.
Aritra Dhar (adhar0919) created this task.Jul 28 2019, 9:22 PM
William Reynish (billreynish) lowered the priority of this task from 90 to 30.Jul 29 2019, 12:24 AM
William Reynish (billreynish) added a subscriber: William Reynish (billreynish).
You say the room has been 'deformed' but it's impossible to tell if this is actually a bug. You'll need to supply a demo blend file with instructions how to reproduce the issue. Thanks.
Alex (SpectreFirst) added a subscriber: Alex (SpectreFirst).EditedJul 29 2019, 11:07 AM
Right now it doesn't look like it was deformed, it looks like it's set to Shade Smooth mode, try setting your walls to Shade Flat by right clicking and choosing Shade Flat or by choosing Object – Shade Flat from the top menu and see if the problem is still there.
Aritra Dhar (adhar0919) added a comment.Jul 29 2019, 11:22 PM
I tried that and it looks a lot better now. Thanks a lot.
Philipp Oeser (lichtwerk) changed the task status from Unknown Status to Resolved.Aug 13 2019, 11:08 AM
Oki, glad to hear, will close then
