Maniphest T67873
View Selected in Graph Editor (Only Selected Curve Keyframes) takes hidden keys into account when calculating zoom
Closed, Resolved
Philipp Oeser (lichtwerk)
Roman (roman13)
Jul 29 2019, 9:14 AM
  • BF Blender
  • Animation & Rigging
Pavel (Pavel_Blend)
Roman (roman13)
Stanislav Ovcharov (Stan1)
Graphics card: GeForce GTX 750 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 388.13
Broken: version: 2.80 (sub 75), branch: master, commit date: 2019-07-24 14:22, hash: rB507ffee6e1f4
Selects hidden Vertex When Only Selected Curve keyframes is enabled,
When Only Selected Curve keyframes is enabled, the hidden Vertex is Selects.
View Selected command does not work correctly
Revisions and Commits
rB Blender
D6237
Roman (roman13) created this task.Jul 29 2019, 9:14 AM
Philipp Oeser (lichtwerk) claimed this task.Jul 29 2019, 10:00 AM
Philipp Oeser (lichtwerk) lowered the priority of this task from 90 to 50.
Philipp Oeser (lichtwerk) added a project: Animation & Rigging.
Can confirm.
Same is true for 2.79 (so not 100% sure this is intended in certain scenarios?).
Confirming for now though, seems reasonable to only frame selected curves keyframes (if this setting is enabled...)
Pavel (Pavel_Blend) added a subscriber: Pavel (Pavel_Blend).Aug 3 2019, 8:53 PM
This behavior also bothers me.
If you enable the "Only Selected Curve Keyframes" mode, then when you press the A key, hidden keyframes will be selected.
I would like the A key select to only visible keyframes.
Stanislav Ovcharov (Stan1) added a subscriber: Stanislav Ovcharov (Stan1).Aug 15 2019, 10:30 AM
Philipp Oeser (lichtwerk) renamed this task from View Selected in Graph Editor to View Selected in Graph Editor (Only Selected Curve Keyframes) takes hidden keys into account when calculating zoom.Nov 12 2019, 6:47 PM
Philipp Oeser (lichtwerk) changed the task status from Unknown Status to Resolved by committing rB355905cb0278: Fix T67873: View Selected in Graph Editor (Only Selected Curve Keyframes) takes….Nov 21 2019, 1:12 PM
Philipp Oeser (lichtwerk) added a commit: rB355905cb0278: Fix T67873: View Selected in Graph Editor (Only Selected Curve Keyframes) takes….
