Maniphest T67884
I cant select armature or pose bones in the 3d viewport.
Closed, Duplicate
None
Daveedo (Hooepr)
Jul 29 2019, 3:32 PM
  • BF Blender
Daveedo (Hooepr)
William Reynish (billreynish)
Operating system:
Graphics card:
Broken: (example: 2.80, edbf15d3c044, master, 2018-11-28, as found on the splash screen)
Problem: I cant select any armature in the blender 8.0 candidate 3. When I go into pose mode I cant move any bones or even click them. Not sure if this is a bug or something messed up in preferences. Help would be appreciated!
Daveedo (Hooepr) created this task.Jul 29 2019, 3:32 PM
William Reynish (billreynish) lowered the priority of this task from 90 to 30.Jul 29 2019, 4:31 PM
William Reynish (billreynish) added a subscriber: William Reynish (billreynish).
There's a chance you've accidentally disabled selectability. Please provide an example blend file so we can take a look. Thanks.
Daveedo (Hooepr) added a comment.Jul 29 2019, 4:52 PM
like the app im using?
Daveedo (Hooepr) added a comment.Jul 29 2019, 5:00 PM
William Reynish (billreynish) added a comment.Jul 29 2019, 5:21 PM
Selecting the armature works normally here. What date is your build from, and which OS are you using?
Daveedo (Hooepr) added a comment.Jul 29 2019, 7:49 PM
it must be something in my preferences, im not sure what it is
William Reynish (billreynish) added a comment.Jul 29 2019, 8:10 PM
Try using factory default settings
Daveedo (Hooepr) added a comment.Jul 29 2019, 8:21 PM
i got nothing it still doesnt work do you want me to send you the model?
Daveedo (Hooepr) added a comment.Jul 29 2019, 11:04 PM
when does the full version of blender 2.8 release?
William Reynish (billreynish) closed this task as a duplicate of T67951: you cannot select bones individually.Jul 31 2019, 10:38 AM
