Maniphest T67905
Issue with transform (resize) effect when resizing images that are larger than render resolution
Closed, Duplicate
None
Mikeycal Meyers (mikeycal)
Jul 29 2019, 10:45 PM
  • BF Blender
Philipp Oeser (lichtwerk)
ronan ducluzeau (zeauro)
Operating system: Ubuntu 18.04 LTS
Graphics card: Nvidia GTX 1060
Broken on all Versions of Blender: 2.79b and 2.8RC2
When you import an image into Blender VSE, that has a larger resolution than the render resolution, blender can't shrink (transform) to show the full image. Instead blender shrinks the cropped image. This has been an issue with Blender as long as I have been teaching it -- since 2013.
  1. Set your render resolution in blender to 1280x720
  2. import an image that is 1920x1080 into the VSE.
  3. Check mark "Offset" in image properties. This will zoom in a cropped version of the image.
  4. Create a Transform Effect strip for the image.
  5. Select "Uniform Scale" on the Transform Strip and shrink the image.
  6. Only the cropped image will shrink.
Mikeycal Meyers (mikeycal) created this task.Jul 29 2019, 10:45 PM
ronan ducluzeau (zeauro) added a subscriber: ronan ducluzeau (zeauro).Jul 30 2019, 11:08 AM
Problem was already reported, confirmed and is still open. T54273
Workaround is to avoid Offset and use Position settings of Transform strip or to use Offset from an Adjustment Layer strip.
Philipp Oeser (lichtwerk) added a subscriber: Philipp Oeser (lichtwerk).Jul 30 2019, 11:35 AM
Will merge into T54273 then
Philipp Oeser (lichtwerk) closed this task as a duplicate of T54273: Large images gets cropped when downscaled in VSE.Jul 30 2019, 11:35 AM
