Title:
Operating system: Windows 7
GPU: Radeon Vega 64, Divider version: 19.4.1
CPU: Intel Core i7-5960X
Broken: All of them
Worked: None
The settings in the proxy panel allow for the Proxies to be saved in the same location as the source.
It is not possible to create a folder that has the same name as a file (including extension), so Blender crashes.
From T67535#741176:
Callback:
N:\Temp\Blender\blender-2.81.0-git.af4dcc6073fa-windows64>N:\Temp\Blender\blender-2.81.0-git.af4dcc6073fa-windows64\blender.exe --debug Switching to fully guarded memory allocator. Blender 2.81 (sub 0) Build: 30/07/2019 17:01 Windows Release argv[0] = N:\Temp\Blender\blender-2.81.0-git.af4dcc6073fa-windows64\blender.exe argv[1] = --debug Note: No (valid) 'C:\Users\admin\AppData\Roaming\Blender Foundation\Blender\2.81\config\startup.blend' found, fall back to built-in default. read file Version 280 sub 39 date unknown hash unknown AL lib: (EE) UpdateDeviceParams: Failed to set 48000hz, got 96000hz instead found bundled python: N:\Temp\Blender\blender-2.81.0-git.af4dcc6073fa-windows64\2.81\python drop file F:\Blender\BugFinds\T67535 VSE crash and failure to update\Cat.blend Read blend: F:\Blender\BugFinds\T67535 VSE crash and failure to update\Cat.blend read file F:\Blender\BugFinds\T67535 VSE crash and failure to update\Cat.blend Version 280 sub 75 date 2019-07-29 14:47 hash f6cb5f54494e Starting work on proxy: F:\Blender\BugFinds\T67535 VSE crash and failure to update\VID_201907_trimmed.mkv\proxy_25_part.avi Couldn't open outputfile! Proxy not built! Starting work on proxy: F:\Blender\BugFinds\T67535 VSE crash and failure to update\VID_201907_trimmed.mkv\proxy_50_part.avi Couldn't open outputfile! Proxy not built! Starting work on index: F:\Blender\BugFinds\T67535 VSE crash and failure to update\VID_201907_trimmed.mkv\record_run.blen_tc Couldn't open index target: F:\Blender\BugFinds\T67535 VSE crash and failure to update\VID_201907_trimmed.mkv\record_run.blen_tc_part! Index build broken! Starting work on index: F:\Blender\BugFinds\T67535 VSE crash and failure to update\VID_201907_trimmed.mkv\free_run.blen_tc Couldn't open index target: F:\Blender\BugFinds\T67535 VSE crash and failure to update\VID_201907_trimmed.mkv\free_run.blen_tc_part! Index build broken! Starting work on index: F:\Blender\BugFinds\T67535 VSE crash and failure to update\VID_201907_trimmed.mkv\interp_free_run.blen_tc Couldn't open index target: F:\Blender\BugFinds\T67535 VSE crash and failure to update\VID_201907_trimmed.mkv\interp_free_run.blen_tc_part! Index build broken! Starting work on index: F:\Blender\BugFinds\T67535 VSE crash and failure to update\VID_201907_trimmed.mkv\record_run_no_gaps.blen_tc Couldn't open index target: F:\Blender\BugFinds\T67535 VSE crash and failure to update\VID_201907_trimmed.mkv\record_run_no_gaps.blen_tc_part! Index build broken! Error : EXCEPTION_ACCESS_VIOLATION Address : 0x000000013F6B067F Module : N:\Temp\Blender\blender-2.81.0-git.af4dcc6073fa-windows64\blender.exe N:\Temp\Blender\blender-2.81.0-git.af4dcc6073fa-windows64>
Exact steps for others to reproduce the error from scratch
- Factory Start-up
- Add video
- In proxy settings select Project
- In the directory set to the same location as the source video
- Build Proxies
- Crash
Also see: T67535#741176
