Maniphest T68027
Curve Arc crash
Closed, Duplicate
None
denys (Gelenov)
Aug 1 2019, 12:18 AM
  • BF Blender
denys (Gelenov)
Philipp Oeser (lichtwerk)
Operating system:
Graphics card:
alpha ... 073fa
add curve - arc .... 75 deg ... modifier screw ... set y axis ... rotate -90 x ... convert to mesh ... go edit mode .... shift alt select bottom hole to fill .... CRASH
denys (Gelenov) created this task.Aug 1 2019, 12:18 AM
Philipp Oeser (lichtwerk) lowered the priority of this task from 90 to 30.Aug 1 2019, 10:02 AM
Cannot reproduce here:
  • is the selection failing/crashing in above file fopr you, too?
  • if not: please provide you .blend file right before selection, so all we have to do is do the selection to reproduce...
Brecht Van Lommel (brecht) closed this task as a duplicate of T68046: Alpha 281 edit mode crash.Aug 4 2019, 12:37 PM
