Maniphest T68046
Alpha 281 edit mode crash
Closed, Archived
Bastien Montagne (mont29)
denys (Gelenov)
Aug 1 2019, 8:42 AM
  • BF Blender
Brecht Van Lommel (brecht)
denys (Gelenov)
Gavin Scott (Zoot)
Germano Cavalcante (mano-wii)
Nathan Letwory (jesterking)
Philipp Oeser (lichtwerk)
Robert Guetzkow (rjg)
Operating system: windows 10 / g3240 3.1 Gz / 6gb ram
Graphics card: Intel(R) HD Graphics Intel 4.3.0 - Build 20.19.15.4835
Broken: (example: 2.80, edbf15d3c044, master, 2018-11-28, as found on the splash screen)
object - edit ... mouse click anywhere - crash
denys (Gelenov) created this task.Aug 1 2019, 8:42 AM
Marcin Twarowski (Tvaroog) added a subscriber: Marcin Twarowski (Tvaroog).Aug 1 2019, 8:53 AM
I couldn't reproduce.
  • Always test with the latest official release from blender.org and daily build from builder.blender.org.
  • You can use Help > Report a Bug in Blender daily builds to automatically fill system information and exact Blender version.
  • Find steps to redo the bug consistently, and include a small and simple .blend file to demonstrate the bug.
  • If there are multiple bugs, make multiple bug reports.
  • Sometimes, driver or software upgrades cause problems. On Windows, try a clean install of the graphics drivers.
denys (Gelenov) updated the task description.Aug 1 2019, 8:56 AM
Nathan Letwory (jesterking) lowered the priority of this task from 90 to 30.Aug 1 2019, 9:45 AM
Nathan Letwory (jesterking) added a subscriber: Nathan Letwory (jesterking).
For now the contents of the System Info file that gets created through Help > Save System Info pasted as reply here would give already better info about what you're running on. As @Marcin Twarowski (Tvaroog) alludes, this could be a driver problem.
Brecht Van Lommel (brecht) merged a task: T68124: alpha crashes in edit mode.Aug 2 2019, 12:34 PM
Brecht Van Lommel (brecht) merged a task: T68031: edit mode crashes.Aug 4 2019, 12:34 PM
Brecht Van Lommel (brecht) merged a task: T68169: crashes on latest windows 10 in edit mode.
Brecht Van Lommel (brecht) merged a task: T68184: Alpha281 Crashes in edit mode.
Brecht Van Lommel (brecht) merged a task: T68186: Alpha281 edit mode crashes - curves test.
Brecht Van Lommel (brecht) updated the task description.
Brecht Van Lommel (brecht) added a subscriber: Germano Cavalcante (mano-wii).
Brecht Van Lommel (brecht) added a subscriber: Robert Guetzkow (rjg).
Brecht Van Lommel (brecht) merged a task: T68210: Alpha 281 Boolean to edit crash.Aug 4 2019, 12:36 PM
Brecht Van Lommel (brecht) merged a task: T68029: shift alt crash .
Brecht Van Lommel (brecht) merged a task: T68027: Curve Arc crash.
Brecht Van Lommel (brecht) added a subscriber: Gavin Scott (Zoot).
Brecht Van Lommel (brecht) added a subscriber: Philipp Oeser (lichtwerk).
Brecht Van Lommel (brecht) added a subscriber: Brecht Van Lommel (brecht).Aug 4 2019, 12:39 PM
@denys (Gelenov), most likely all these bug reports are due to the same problem. It is not needed to create more reports, please reply in this report. If there are more issues we can look into them once this one is fixed.
Please try File > Defaults > Load Factory Settings, and test if you can still get it to crash. There may be an add-on or other preference causing problems.
Marcin Twarowski (Tvaroog) removed a subscriber: Marcin Twarowski (Tvaroog).Aug 4 2019, 1:15 PM
Brecht Van Lommel (brecht) mentioned this in T68267: alpha 281 still crashing in edit mode.Aug 5 2019, 5:44 PM
Brecht Van Lommel (brecht) merged a task: T68267: alpha 281 still crashing in edit mode.
Bastien Montagne (mont29) changed the task status from Unknown Status to Archived.Aug 13 2019, 5:56 PM
Bastien Montagne (mont29) added a subscriber: Bastien Montagne (mont29).
You are using 2 years old drivers, please update them from Intel website.
denys (Gelenov) added a comment.Aug 14 2019, 10:54 AM
Udated intel drivers 8/13 ... downloaded alpha ... edit mode ... crashed on first click :) i will wait for next alpha today sometime ... in edit mode verts are in orange color ? anyhow different to 2.8 edit mode ... is this normal ?
