Operating system: Linux-4.13.10-041310-generic-x86_64-with-debian-stretch-sid 64 Bits
Graphics card: GeForce GTX 1050/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 390.67
Broken: version: 2.81 (sub 0), branch: master, commit date: 2019-07-30 20:50, hash: rB5359b7a03307
I'm seeing very odd selection issues, where some faces can't seem to be selected and the selection goes through the mesh to the other side. Normal(click) selection as well as circle and box select are affected. I don't think it's related to the blend file or the objects/meshes. It's a fresh startup file with just the two objects added.
Most unusual is, how the issue only starts presenting itself, once the blend is loaded the second time in the same Blender session.
- open the blend
- start selecting geometry on either object's mesh, everything should work as expected
- load the same blend again, and try selecting the mesh geometry again
- some faces should resist being selected and faces on the other side should select
- turn the view and now other faces shold be (un)selectable
