Operating system: Windows 8.1
Graphics card: GTX 970
Broken: 2.80.75
Following removal of the default cube from the startup scene (and saving it as the new default), if the viewport is zoomed a certain distance inward (using either the UI, the mouse or the 'Emulate 3-button Mouse' setting) neither the zoom or pan tools will continue to function.
When this issue occurs the rotate tool also no longer pivots on the center point.
- Open the default startup scene (possibly works with any startup scene originally containing an initial object). Have the view mode set to perspective.
- Delete the cube.
- Save the modified scene as the the default startup scene (*File>Defaults>Save Startup File*).
- Restart Blender.
- Add an object to the scene.
- Zoom in close.
Upon the last step the zoom/pan/rotate tools are affected by the issue. I've attached the modified startup.blend file that produced the issue on my install, along with a video capture of the issue.
