Maniphest T68096
Object disappears in Viewport when Shading is set to Render while using Multires Modifier
Closed, Duplicate
None
Dee Grimm (total_legend)
Aug 2 2019, 2:22 AM
  • BF Blender
Operating system: Windows 10
Graphics card: GTX1080
Broken: (2.80.75)
Worked: (2.79)
When adding a Multires Mod to an object, that object disappears in the view port when the shading is set to Render. When I disable the Multires Mod, the object displays in the view port as expected. The Multires Mod does contain sculpting data and it's being done under Cycles.
I am not 100% sure how to replicate it, it simply exists on my current project. The collections and objects are not hidden, but when I turn off the Multires Mod, the object reappears in the viewport.
I don't want to attach my project to be downloaded publicly, I could email it if you need to look at it. Otherwise attached are some screenshots to illustrate what I mean.
Image 1 is what I see when Blender Launches. The Viewport shows the object which is labeled Uniform.Work.Skirt.A.
Image 2 is what happens when I set the Viewport shading to Render. The Uniform.Work.Skirt.A object disappears.
Image 3 shows that the Uniform.Work.Skirt.A object returns when the Multires Mod is disabled.
Image 4 shows that the Multires Mod is re-enabled, in the Viewport the Uniform.Work.Skirt.A object disappears again, but when doing a full Render, the Uniform.Work.Skirt.A object is rendered as expected.
Dee Grimm (total_legend) created this task.Aug 2 2019, 2:22 AM
