Maniphest T68300
UV Smart UV Project "Island Margin" issue
Closed, Duplicate
Sebastian Parborg (zeddb)
Hirotaka Imagawa (garykiritake)
Aug 6 2019, 10:20 AM
  • BF Blender
Germano Cavalcante (mano-wii)
Graphics card: Quadro P2000/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 431.02
Broken: version: 2.81 (sub 1), branch: master, commit date: 2019-08-05 18:52, hash: rBcdeda1fa6cea
Using "0.02" margin for "Island Margin" in "Smart UV Project" menu, you can see the different width around each islands.
This is the result of Smart UV Project by 2.81.
And old 2.78c's result is below.
Both results were using same parameters;Angle Limit 66.00, Island Margin 0.02, Area Weight 0.0.
I attached the .blend.
In this case, all faces are separated by all edges, so all faces should be arranged with same margin around them as the result of 2.78c.
Even if the algorithm has been changed, some Islands doesn't have correct margin.
Thanks.
Related Objects
Mentioned Here
rB0403a2f78502: Fix T53997: island_margin in bpy.ops.uv.smart_project seems to have no effect
Hirotaka Imagawa (garykiritake) created this task.Aug 6 2019, 10:20 AM
Germano Cavalcante (mano-wii) assigned this task to Sebastian Parborg (zeddb).Aug 6 2019, 2:59 PM
Germano Cavalcante (mano-wii) lowered the priority of this task from 90 to 50.
Germano Cavalcante (mano-wii) added subscribers: Sebastian Parborg (zeddb), Germano Cavalcante (mano-wii).
@Sebastian Parborg (zeddb), you worked in this area a while ago (rB0403a2f7). Can you take a look?
Sebastian Parborg (zeddb) closed this task as a duplicate of T63391: Smart UV Unwrap - bad island spaceing.Aug 7 2019, 10:24 AM
