Hi, I updated animation_animall to Blender 2.8. The patch should be applied to addons_contrib. It includes D3162, for which I never assigned any reviewers :/
*(edit, this has been applied)*I copy below what I said on that differential:
- This patch allows keying only selected points for meshes, curves and lattices.
- Fix keying POLY splines
- Add fcurves to groups by element (Vertex, Edge, etc.), to keep the dope sheet and graph editor less cluttered
- This does not currently work for curves: the fcurves are unassigned on switching modes. Presumably due to a bug in Blender, since it works for meshes.
Note that the bug for curves is still there.
The patch also includes some new cleanups like variable names’ case and grouping of properties to avoid cluttering window_manager.
Right now, it is still in addons_contrib but I believe it is ready for review, to be included in addons. As per T63750, it may need discussion.
(Here’s the python file, in case it’s more convenient…)
*(edit, this has been applied)*EDIT: Update files with an overlooked bugfix…
