Maniphest T68339
Blender crashes using GPU compute cuCtxCreate Illegal Address
Closed, Resolved
Germano Cavalcante (mano-wii)
Karl Northfell (GlobalKrampus)
Aug 6 2019, 9:47 PM
  • BF Blender
  • Render & Cycles
gbayliss (gbayliss)
Philipp Oeser (lichtwerk)
William (Equil1brs)
Graphics card: GeForce GTX 1080/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 431.70
After rendering with the GPU a number of times it will then constantly crash when using GPU compute. If it doesn't crash it will get CUDA errors and refuse to render.
A full reinstall and updating of Nvidia drivers was performed with no success.
This type of crash happens even with the default scene. A coworker with a similar machine including the same video card (GTX 1080) but different CPU does not appear to be having these CUDA errors or crashes.
Karl Northfell (GlobalKrampus) created this task.Aug 6 2019, 9:47 PM
gbayliss (gbayliss) added a subscriber: gbayliss (gbayliss).Aug 16 2019, 5:58 PM
@Karl Northfell (GlobalKrampus) I have a similar issue if I let my machine go to sleep, it doesn't reinitialize the GPU after waking up again. Is it possible that this is related to power settings, screensaver etc?
Germano Cavalcante (mano-wii) mentioned this in T68600: cuda error at cuctxcreate invalid pc.Dec 26 2019, 8:17 PM
Germano Cavalcante (mano-wii) merged a task: T68600: cuda error at cuctxcreate invalid pc.
Germano Cavalcante (mano-wii) added a project: Render & Cycles.
Germano Cavalcante (mano-wii) added subscribers: William (Equil1brs), Germano Cavalcante (mano-wii).
Philipp Oeser (lichtwerk) renamed this task from Blender crashes using GPU compute to Blender crashes using GPU compute cuCtxCreate Illegal Address.Dec 28 2019, 1:46 PM
Philipp Oeser (lichtwerk) changed the task status from Needs Triage to Needs Information from User.Dec 28 2019, 1:58 PM
Just to get this clear:
  • you are rendering the default scene via GPU (a number of times -- is the number fixed/reproducable?)
  • then after some unfortunate mystery you are trying to render the default scene via GPU again and get the following error cuCtxCreate: Illegal address -- or crash
  • Is this correct?
Your screenshot implies there is some other scene loaded [80M is too large for the default scene?]
  • are you really sure it is not tied to a particular scene?
(if it turns out to be tied to a particular scene, please attach that here...)
Also, since this report is a bit older [sorry btw. this has been lying around for so long...], could you check if this is still an issue with 2.81a (or a fresh build from https://builder.blender.org/download/)
Karl Northfell (GlobalKrampus) added a comment.Jan 3 2020, 6:05 PM
I just tested scenes from that time on a newly installed 2.81a stable build and did not get any CUDA errors. There were a few crashes to desktop but they were both from older scenes using alembic files, when testing the default scene there were no crashes or CUDA errors. You can probably consider this issue closed.
Germano Cavalcante (mano-wii) closed this task as Resolved.Jan 3 2020, 6:16 PM
Germano Cavalcante (mano-wii) claimed this task.
Thanks for the information.
In this case I will close this report and reopen what was merged here as it may be a different issue.
