Operating system: Darwin-17.7.0-x86_64-i386-64bit 64 Bits
Graphics card: AMD Radeon HD - FirePro D500 OpenGL Engine ATI Technologies Inc. 4.1 ATI-1.68.20
Broken: version: 2.80 (sub 74), branch: master, commit date: 2019-07-18 14:52, hash: rB38d4483c6a51
Attempting to render blender FLIP fluids animation. Rendering single frame works but crashes almost immediately when rendering the animation. Even the simplest sim will crash.
Create box. Tab and scale up. Add FLIP fluids add-on, set box as domain. Add Mesh > Sphere. Set as inflow, with some adjusted velocity settings. Hit Bake. Add materials as needed. Click 'Transparency' in order to render with Alpha. 'Render Image' as test frame (works). 'Render Animation' (crashes within a few frames, often times on the very first frame.
Anything I do will crash it. Doesn't matter if it contains an objects in it or if it is a simple outflow animation. Tried both CPU and GPU rendering
