Maniphest T68533
Blender Crashes While Switching from solid to render view and also when try to add/edit materials
Closed, Archived
Bastien Montagne (mont29)
Maaz Saleem (wolfiedesigns)
Aug 11 2019, 6:51 AM
  • BF Blender
Abid Maqbool (cto.abid)
Demeter Dzadik (Mets)
Operating system: Core i3-3200 @3.2 GHz
Graphics card: Nvidia GTX 960 2GB
Blender Version : 2.80 + 2.80 stable
I download the latest version of blender and it closes/crashes after sometime, it also crashes when i try to add/edit materails or switching from solid to render view or lookdev view
Optional Notes
I was also using all the previous versions of blender and they were working fine!
Maaz Saleem (wolfiedesigns) created this task.Aug 11 2019, 6:51 AM
Maaz Saleem (wolfiedesigns) updated the task description.Aug 11 2019, 6:53 AM
Abid Maqbool (cto.abid) added a subscriber: Abid Maqbool (cto.abid).Aug 11 2019, 7:00 AM
@Maaz Saleem (wolfiedesigns) Please confirms:
for quick supports you can try: https://blender.chat/channel/support
Abid Maqbool (cto.abid) lowered the priority of this task from 90 to 30.Aug 11 2019, 7:01 AM
I think, the prob is one of thous. Please apply above steps and let we know...
Maaz Saleem (wolfiedesigns) added a comment.Aug 11 2019, 8:06 AM
I've tried all of the obove solutions but still getting the issue!
Demeter Dzadik (Mets) added a subscriber: Demeter Dzadik (Mets).Aug 11 2019, 10:37 PM
A GTX 960 definitely hits the minimum requirements. Just to confirm, you made sure you have the latest drivers?
When you say previous blender versions worked fine, do you mean 2.7x or previous 2.80 builds?
Does it crash in the mentioned ways even in the startup .blend with the default cube, or only in a specific project?
Abid Maqbool (cto.abid) added a comment.Aug 12 2019, 5:48 PM
@Maaz Saleem (wolfiedesigns) If you can confirm in completely fresh blender.. or try to load factory setting in Blender and save startup file... then confirms again
Bastien Montagne (mont29) added a subscriber: Bastien Montagne (mont29).Aug 20 2019, 12:34 PM
Please attach as text file here the report generated by Help -> System Info (do not paste it directly in comment).
Bastien Montagne (mont29) changed the task status from Unknown Status to Unknown Status.Aug 27 2019, 12:14 PM
