Maniphest T68536
Cannot rename annotation notes with double clicking in the properties panel
Closed, DuplicateKNOWN ISSUE
None
Alexis (sch.alexis)
Aug 11 2019, 11:08 AM
  • BF Blender
  • User Interface
Alexis (sch.alexis)
Antonio Vazquez (antoniov)
Christoph Werner (Taros)
Christopher_Anderssarian
dark999 (dark999)
Jacques Lucke (JacquesLucke)
Philipp Oeser (lichtwerk)
Operating system: Windows 10
Graphics card: NVidia GTX 960M
Broken: 2.80.75
Worked:
Open new 2D Animation project
Select Object Mode
Select Annotation tools
Open Properties panel
Click new note with "+" button
Try double clicking but it doesn't work
Alexis (sch.alexis) created this task.Aug 11 2019, 11:08 AM
Christopher_Anderssarian added subscribers: Antonio Vazquez (antoniov), Christopher_Anderssarian.Aug 11 2019, 2:58 PM
@Antonio Vazquez (antoniov) This affects the top bar as well...
Antonio Vazquez (antoniov) added a comment.EditedAug 11 2019, 3:46 PM
I cannot repoduce it on Windows. I can rename with double cilick or with Ctrl+LMB in the properties.
To rename in Popover only works Ctrl+LMBbut this is not related to GPencil or Annotations only, the issue, if exist, is with any list in popovers.
Christopher_Anderssarian added a comment.Aug 11 2019, 3:54 PM
Can you do it with this blend file? For me it still takes 2 clicks (with Ctrl+LMB), either way the tool tip is incorrect then...
I'm using: blender-2.81.0-git.22cdadaa32c7-windows64
Alexis (sch.alexis) added a comment.Aug 11 2019, 5:25 PM
CTRL + LMB double click works fine
LMB double click doesn't work
The tooltip message do not specify CTRL
dark999 (dark999) added a subscriber: dark999 (dark999).Aug 11 2019, 6:07 PM
Annotations rename.blend work fine for me, i can rename Note with double click on text without Ctrl key ( i use LeftClickSelect mouse setting)
my config: linux Blender 2.80-stable AMD FX8350, 16GB DDR3, GTX690 2+2 GB VRam- Nvidia drivers 430.40
Have you same problem with Blender 2.80 Stable release?
Alexis (sch.alexis) added a comment.Aug 11 2019, 6:37 PM
Blender 2.80.75 is the latest version suggested for Windows on the site.
Jacques Lucke (JacquesLucke) lowered the priority of this task from 90 to 50.Aug 12 2019, 5:51 PM
Jacques Lucke (JacquesLucke) added a subscriber: Jacques Lucke (JacquesLucke).
I can reproduce the issue in ubuntu. Double click to rename does not work. Ctrl+LMB does work.
Antonio Vazquez (antoniov) added a comment.Aug 12 2019, 11:05 PM
@Jacques Lucke (JacquesLucke) It looks this is a general problem of the list, not related to Gpencil, no?
Jacques Lucke (JacquesLucke) added a comment.Aug 12 2019, 11:40 PM
Cannot say for sure right now, but yeah, this seems to be a more general issue.
@Alexis (sch.alexis) can you find a similar problem somewhere else in Blender?
Alexis (sch.alexis) added a comment.Aug 13 2019, 8:57 PM
I'm currently on a business trip. I tell you that the day after tomorrow.
Christoph Werner (Taros) added a subscriber: Christoph Werner (Taros).EditedAug 16 2019, 11:44 AM
I use Windows 10.
@Jacques Lucke (JacquesLucke) Yes. It seem to be a global problem. I've the same problem when trying to rename Shape Keys in the shape key list. Double click on a Shape key slot using a simple scene with a few models works fine, but as soon as my scene grows to a lot of objects, I've to double click super fast to rename something. Sometimes it doesn't work.
CTRL+LBM to rename is something I didn't know before and would actually never try. This is a very custom solution to rename elements, isn't it? I don't know any other software that use CTRL+LBM to rename something... It's reserved to expand a selection list actually.
I hope it will be fixed soon, to fulfil more standards.
Best wishes
Chris
Philipp Oeser (lichtwerk) added a project: User Interface.Aug 21 2019, 2:06 PM
Dalai Felinto (dfelinto) added a project: Tracker Curfew.Dec 23 2019, 4:33 PM
Philipp Oeser (lichtwerk) triaged this task as Low priority.Feb 3 2020, 9:32 AM
Philipp Oeser (lichtwerk) removed a project: Tracker Curfew.
Philipp Oeser (lichtwerk) changed the subtype of this task from "Report" to "Known Issue".
