Maniphest T68542
Keyboard "A" to deselect all vertices only works inconsistently
Closed, Resolved
Julian Eisel (Severin)
Eagle Gamma (eaglegamma)
Aug 11 2019, 1:11 PM
  • BF Blender
Bastien Montagne (mont29)
dark999 (dark999)
Wo!262 (wo262)
Operating system: Windows 10
Graphics card: Built-in Intel on HP laptop
Broken: 2.80
Worked: 2.79
Pressing "A" on the keyboard often does not deselect all vertices while in Edit Mode.
In default startup, press Tab to switch into Edit Mode. Press "A" once to select all vertices. Press "A" again to deselect all vertices. Sometimes this works, sometimes it does not.
Revisions and Commits
rB Blender
Related Objects
Mentioned In
rB35a9a85b2708: Fix T68542: ParticleSystem.uv_on_emitter returns always 0,0 while Particle.
Mentioned Here
T68442: ParticleSystem.uv_on_emitter returns always 0,0 while Particle.uv_on_emitter returns a value
Eagle Gamma (eaglegamma) created this task.Aug 11 2019, 1:11 PM
dark999 (dark999) added a subscriber: dark999 (dark999).EditedAug 11 2019, 2:04 PM
[EDIT] Selection and deselection work as expected and designed. To deselect you must use Alt+A or double press A, this changes was made many months ago in 2.80Beta age
Wo!262 (wo262) added a subscriber: Wo!262 (wo262).Aug 11 2019, 4:14 PM
It's not as before. Pressing A once always selects, and pressing Alt+A deselects. You can also double tap A to deselect but it has to be fast. If you want to use the old behaviour from 2.79, go to Preferences, keymap, and click on Select All toggles
Julian Eisel (Severin) changed the task status from Unknown Status to Archived.Aug 11 2019, 4:52 PM
Julian Eisel (Severin) claimed this task.
Julian Eisel (Severin) added a subscriber: Julian Eisel (Severin).
Previous comments are correct. This seems to work as designed. Closing the report.
Bastien Montagne (mont29) changed the task status from Archived to Resolved by committing rB35a9a85b2708: Fix T68542: ParticleSystem.uv_on_emitter returns always 0,0 while Particle..Aug 12 2019, 11:47 AM
Bastien Montagne (mont29) added a commit: rB35a9a85b2708: Fix T68542: ParticleSystem.uv_on_emitter returns always 0,0 while Particle..
Bastien Montagne (mont29) added a subscriber: Bastien Montagne (mont29).Aug 12 2019, 11:48 AM
Gah sorry, wrong number in commit message, should have been T68442... :(
Bastien Montagne (mont29) mentioned this in rB35a9a85b2708: Fix T68542: ParticleSystem.uv_on_emitter returns always 0,0 while Particle..Aug 12 2019, 11:49 AM
