Operating system: Microsoft Windows 10 Pro
Broken: (example: 2.80, edbf15d3c044, master, 2018-11-28, as found on the splash screen)
We're getting an error when importing an OBJ. I think it's be cause some chines character in the model, but I'm sure you can shine some light on it.
python
File "C:\Program Files (x86)\blender\2.80\scripts\addons\io_scene_obj\__init__.py", line 145, in execute
return import_obj.load(context, **keywords)
File "C:\Program Files (x86)\blender\2.80\scripts\addons\io_scene_obj\import_obj.py", line 1215, in load
use_image_search, float_func)
File "C:\Program Files (x86)\blender\2.80\scripts\addons\io_scene_obj\import_obj.py", line 407, in create_materials
context_material_name, img_data, line, 'Ka')
File "C:\Program Files (x86)\blender\2.80\scripts\addons\io_scene_obj\import_obj.py", line 139, in load_material_image
image = obj_image_load(context_imagepath_map, line, DIR, use_image_search, relpath)
File "C:\Program Files (x86)\blender\2.80\scripts\addons\io_scene_obj\import_obj.py", line 86, in obj_image_load
imagepath = os.fsdecode(b" ".join(filepath_parts[i:]))
File "C:\Program Files (x86)\blender\2.80\python\lib\os.py", line 823, in fsdecode
return filename.decode(encoding, errors)
UnicodeDecodeError: 'utf-8' codec can't decode byte 0xb1 in position 22: invalid start byte
location: <unknown location>:-1I've attached the geometry that raises this issue.
If in fact the issue is caused with the characters in the path or something, do you have suggestion on how to fix it?
Appreciate your help in advance.
-Ali
