Maniphest T68735
Eevee world can't display.
Closed, Archived
Clément Foucault (fclem)
Yee Ta Ta (IBlender)
Aug 16 2019, 4:36 PM
  • BF Blender
Windows 10 64bit , NVIDIA GTX1080,i7-6700k,Ram:32GB
WIN 10 1903 version,GPU drivers 431.60 version.
Broken: Version 2.8 of the official website, not the Experimental version.
I don't know is this a bug,or a Limitations? I can't see the restrictions related to this.
This is Eevee Limitations Manual
This is my test file.
In the video,I use three big nodes. All nodes aren't using images, it's procedural.
When they are separately, they can be displayed normally,but when I link to the third one,it will first LAG and then display the Pink purple.
I would think this is a bug because I have another set of world nodes with 10 sets of connected nodes.
Related Objects
Yee Ta Ta (IBlender) created this task.Aug 16 2019, 4:36 PM
Yee Ta Ta (IBlender) updated the task description.Aug 16 2019, 4:40 PM
Yee Ta Ta (IBlender) updated the task description.Aug 16 2019, 4:44 PM
Yee Ta Ta (IBlender) updated the task description.Aug 16 2019, 4:52 PM
Yee Ta Ta (IBlender) updated the task description.Aug 16 2019, 4:59 PM
Clément Foucault (fclem) changed the task status from Unknown Status to Unknown Status.Aug 16 2019, 11:34 PM
Clément Foucault (fclem) claimed this task.
Clément Foucault (fclem) added a subscriber: Clément Foucault (fclem).
There is a limit of instruction a shader can contain in Eevee, and this is dependant on which driver and GPU you use.
You use Noise Texture which are maybe the most expensive node after the BSDFs. So you run out of instructions.
Our shader compilation error reporting is not good. If your shader is purple you should check the console for a more detailled error.
Will close as archive because it's a limitation. But depending on the error you get from the console we might reopen.
Yee Ta Ta (IBlender) added a comment.EditedAug 17 2019, 7:51 AM
Hi,this is console detailed error.
Please take a look, thank you.@Clément Foucault (fclem)
If it is not complete or missing, please let me know, I am not familiar with this aspect.
GPUShader: linking error:
Fragment info
Internal error: assembly compile error for fragment shader at offset 1620284:
  • error message --
line 65893, column 1: error: too many instructions
  • internal assembly text --
!!NVfp5.0
OPTION NV_internal;
OPTION NV_gpu_program_fp64;
OPTION NV_bindless_texture;
  1. cgc version 3.4.0001, build date Jul 17 2019
  2. command line args:
#vendor NVIDIA Corporation
#version 3.4.0.1 COP Build Date Jul 17 2019
#profile gp5fp
#program main
#semantic viewBlock : BUFFER[0]
#semantic common_block : BUFFER[1]
#semantic probe_block : BUFFER[2]
#semantic grid_block : BUFFER[3]
#semantic planar_block : BUFFER[4]
#semantic shadow_block : BUFFER[5]
#semantic light_block : BUFFER[6]
#semantic nodeTree : BUFFER[7]
#semantic ModelMatrix
#semantic ModelMatrixInverse
#semantic colorBuffer
#semantic depthBuffer
#semantic maxzBuffer
#semantic minzBuffer
#semantic planarDepth
#semantic outputSsrId
#semantic texHammersley
#semantic texJitter
#semantic sampleCount
#semantic invSampleCount
#semantic utilTex
#semantic horizonBuffer
#semantic irradianceGrid
#semantic probePlanars
#semantic probeCubes
#semantic shadowCubeTexture
#semantic shadowCascadeTexture
#semantic refractionDepth
#semantic inScattering
#semantic inTransmittance
#semantic volumeColor
#semantic backgroundAlpha
#semantic samp0
#semantic unfinvobmat
#semantic unfcameratexfactors
#var int gl_FrontFacing : $vin.FACE_FLAT : SSA : -1 : 0
#var float4x4 ViewProjectionMatrix : BUFFER[0] : buffer[0][0], 4 : -1 : 0
#var float4x4 ViewProjectionMatrixInverse : BUFFER[0] : buffer[0][64], 4 : -1 : 0
#var float4x4 ViewMatrix : BUFFER[0] : buffer[0][128], 4 : -1 : 0
#var float4x4 ViewMatrixInverse : BUFFER[0] : buffer[0][192], 4 : -1 : 1
#var float4x4 ProjectionMatrix : BUFFER[0] : buffer[0][256], 4 : -1 : 1
#var float4x4 ProjectionMatrixInverse : BUFFER[0] : buffer[0][320], 4 : -1 : 1
#var float4 clipPlanes[0] : : buffer[0][384] : -1 : 0
#var float4 CameraTexCoFactors : BUFFER[0] : buffer[0][480] : -1 : 0
#var float4x4 pastViewProjectionMatrix : BUFFER[1] : buffer[1][0], 4 : -1 : 0
#var float4 viewVecs[0] : : buffer[1][64] : -1 : 0
#var float2 mipRatio[0] : : buffer[1][96] : -1 : 0
#var float4 aoParameters[0] : : buffer[1][256] : -1 : 0
#var int4 volTexSize : BUFFER[1] : buffer[1][288] : -1 : 0
#var float4 volDepthParameters : BUFFER[1] : buffer[1][304] : -1 : 0
#var float4 volInvTexSize : BUFFER[1] : buffer[1][320] : -1 : 0
#var float4 volJitter : BUFFER[1] : buffer[1][336] : -1 : 0
#var float4 volCoordScale : BUFFER[1] : buffer[1][352] : -1 : 0
#var float volHistoryAlpha : BUFFER[1] : buffer[1][368] : -1 : 0
#var float volLightClamp : BUFFER[1] : buffer[1][372] : -1 : 0
#var float volShadowSteps : BUFFER[1] : buffer[1][376] : -1 : 0
#var bool volUseLights : BUFFER[1] : buffer[1][380] : -1 : 0
#var float4 ssrParameters : BUFFER[1] : buffer[1][384] : -1 : 0
#var float ssrBorderFac : BUFFER[1] : buffer[1][400] : -1 : 0
#var float ssrMaxRoughness : BUFFER[1] : buffer[1][404] : -1 : 0
#var float ssrFireflyFac : BUFFER[1] : buffer[1][408] : -1 : 0
#var float ssrBrdfBias : BUFFER[1] : buffer[1][412] : -1 : 0
#var bool ssrToggle : BUFFER[1] : buffer[1][416] : -1 : 0
#var bool ssrefractToggle : BUFFER[1] : buffer[1][420] : -1 : 0
#var float sssJitterThreshold : BUFFER[1] : buffer[1][424] : -1 : 0
#var bool sssToggle : BUFFER[1] : buffer[1][428] : -1 : 0
#var bool specToggle : BUFFER[1] : buffer[1][432] : -1 : 0
#var int laNumLight : BUFFER[1] : buffer[1][436] : -1 : 0
#var int prbNumPlanar : BUFFER[1] : buffer[1][440] : -1 : 0
#var int prbNumRenderCube : BUFFER[1] : buffer[1][444] : -1 : 0
#var int prbNumRenderGrid : BUFFER[1] : buffer[1][448] : -1 : 0
#var int prbIrradianceVisSize : BUFFER[1] : buffer[1][452] : -1 : 0
#var float prbIrradianceSmooth : BUFFER[1] : buffer[1][456] : -1 : 0
#var float prbLodCubeMax : BUFFER[1] : buffer[1][460] : -1 : 0
#var float prbLodPlanarMax : BUFFER[1] : buffer[1][464] : -1 : 0
#var int hizMipOffset : BUFFER[1] : buffer[1][468] : -1 : 0
#var int rayType : BUFFER[1] : buffer[1][472] : -1 : 0
#var float rayDepth : BUFFER[1] : buffer[1][476] : -1 : 0
#var float4 probes_data[0].position_type : : buffer[2][0] : -1 : 0
#var float4 probes_data[0].attenuation_fac_type : : buffer[2][16] : -1 : 0
#var float4x4 probes_data[0].influencemat : : buffer[2][32], 4 : -1 : 0
#var float4x4 probes_data[0].parallaxmat : : buffer[2][96], 4 : -1 : 0
#var float4x4 grids_data[0].localmat : : buffer[3][0], 4 : -1 : 0
#var int4 grids_data[0].resolution_offset : : buffer[3][64] : -1 : 0
#var float4 grids_data[0].ws_corner_atten_scale : : buffer[3][80] : -1 : 0
#var float4 grids_data[0].ws_increment_x_atten_bias : : buffer[3][96] : -1 : 0
#var float4 grids_data[0].ws_increment_y_lvl_bias : : buffer[3][112] : -1 : 0
#var float4 grids_data[0].ws_increment_z : : buffer[3][128] : -1 : 0
#var float4 grids_data[0].vis_bias_bleed_range : : buffer[3][144] : -1 : 0
#var float4 planars_data[0].plane_equation : : buffer[4][0] : -1 : 0
#var float4 planar
Fragment info
  • error message --
!!NVfp5.0
OPTION NV_internal;
#profile gp5fp
#program main
#semantic texJitter
#semantic utilTex
#semantic samp0
#var float4 planar
Fragment info
Internal error: assembly compile error for fragment shader at offset 1601536:
  • error message --
line 65884, column 1: error: too many instructions
!!NVfp5.0
OPTION NV_internal;
OPTION ARB_draw_buffers;
#profile gp5fp
#program main
#semantic utilTex
#semantic samp0
#var float4 gl_FragCoord : $vin.WPOS : WPOS : -1 : 1
#var float4x4 ProjectionMatrixInverse : BUFFER[0] : buffer[0][320], 4 : -1 : 0
#var float4 viewVecs[0] : : buffer[1][64] : -1 : 1
#var float4 volDepthParameters : BUFFER[1] : buffer[1][304] : -1 : 1
#var float4 volInvTexSize : BUFFER[1] : buffer[1][320] : -1 : 1
#var float4 volJitter : BUFFER[1] : buffer[1][336] : -1 : 1
#var float4 volCoordScale : BUFFER[1] : buffer[1][352] : -1 : 1
#var float4 planars_data[0].clip_vec_x_fade_scale : : buffer[4][16] : -1 : 0
Fragment info
  • error message --
!!NVfp5.0
OPTION NV_internal;
#profile gp5fp
#program main
#semantic utilTex
#semantic samp0
Fragment info
  • error message --
!!NVfp5.0
OPTION NV_internal;
#profile gp5fp
#program main
#semantic utilTex
#semantic samp0
Fragment info
  • error message --
!!NVfp5.0
OPTION NV_internal;
#profile gp5fp
#program main
#semantic texJitter
#semantic utilTex
#semantic samp0
#var float4 planar
Fragment info
  • error message --
!!NVfp5.0
OPTION NV_internal;
#profile gp5fp
#program main
#semantic texJitter
#semantic utilTex
#semantic samp0
#var float4 planar
Clément Foucault (fclem) added a comment.Aug 17 2019, 12:09 PM
Well here you go:
it's a limitation of the driver.
Clément Foucault (fclem) added a comment.Aug 17 2019, 12:11 PM
BTW next time, attach the output of the console as a text file to your message instead of pasting it.
Evan Wilson (EAW) mentioned this in T76360: Eevee doesn't render shadow.May 3 2020, 5:26 AM
