Operating system: windows 10 pro
Graphics card: HD 4000
2.80
2.79
everytime I try to use EEvee crashed and exit
| Bastien Montagne (mont29) |
| Vladimir (greatmantis) | |
| Aug 19 2019, 3:20 PM |
| dark999 (dark999) |
| Emir Sinan Gürlek (filibis) |
| Philipp Oeser (lichtwerk) |
2.80
2.79
This problem is already reported many time, it is know hardware limitation of Intel HD 4000 and older Intel GPU, thus this hardware not meet minimum Blender 2.80 requirement.
To try mitigate this problem you can upgrade GPU drivers from Intel support site
The operating system, main memory size, GPU brand and model, GPU driver version and Blender hash or its build date may be needed by developers to investigate this issue
Next time you want report a bug you can use Help > Report a Bug item and strictly compile following proposed form, all text from [ to ] must be edited. You must clearly describe steps to reproduce issue and attach a simplest possible .blend file as request.
Before you made a new bug report you must use Search box (upper right on Bug Report page) to check if bug/problem is already reported from others users. Duplicating bugreport is a waste of time and resources for developers
Thank You
