Maniphest T68957
Material becomes transparent as soon as alpha blend is selected
Closed, Archived
Clément Foucault (fclem)
Robert S (eobet)
Aug 21 2019, 9:40 AM
  • BF Blender
  • EEVEE & Viewport
dark999 (dark999)
Philipp Oeser (lichtwerk)
Robert S (eobet)
Operating system: Windows 10 1903
Graphics card: 1080
Broken: 2.80 release
Even if you set a material to 1.0 alpha, it becomes transparent when Alpha Blend blend mode is selected.
See description. There might be a technical reason for this, but from a user perspective, alpha 1.0 should never have any transparency whatsoever.
If there is a hard technical limitation, I would suggesting removing the "blend mode" option altogether, and just handling setting the different modes behind the scenes automatically (which should be the case anyway for blend modes).
Robert S (eobet) created this task.Aug 21 2019, 9:40 AM
dark999 (dark999) added a subscriber: dark999 (dark999).Aug 21 2019, 11:03 AM
You forgot to upload a simplest possible .blend file to reproduce this issue and file generated from Help > Save System Info as request in Bug template
The operating system, main memory size, GPU brand and model, GPU driver version and Blender hash or its build date may be needed by developers to investigate this issue
Update your GPU drivers from Nvidia support site can solve/mitigate this problem
thank you
Philipp Oeser (lichtwerk) lowered the priority of this task from 90 to 80.Aug 21 2019, 12:47 PM
Philipp Oeser (lichtwerk) added projects: Eevee, GPU / Viewport.
Philipp Oeser (lichtwerk) added subscribers: Clément Foucault (fclem), Philipp Oeser (lichtwerk).
This is also related to the sorting problem, see https://docs.blender.org/manual/en/dev/render/eevee/materials/settings.html#sorting-problem.
Similar as mentioned in T68956.
Not sure why you would use an Alpha Blend mode if you want Alpha=1.0?
But I have seen this reported before tbh.
I assume determining the overall Alpha in a (complex) shader tree could be quite a hassle, so doing this "behind the scenes" might not be considered atm.
So to me this doesnt look like a bug.
@Clément Foucault (fclem): last time asking (promise!): all of these Alpha Blend Sorting reports can be closed, right?
Clément Foucault (fclem) changed the task status from Unknown Status to Archived.Aug 21 2019, 2:57 PM
Clément Foucault (fclem) claimed this task.
Yes, determining automatically can be tricky and not error free. Also we still have multiple alpha blend mode available. That said, removing the opaque is under consideration.
If the problem is really what @Philipp Oeser (lichtwerk) is describing then we can close the report. If it's another thing, we can reopen.
Clément Foucault (fclem) edited projects, added EEVEE & Viewport; removed GPU / Viewport, Eevee.Jun 19 2020, 11:05 PM
