Maniphest T69054
Crash on file open
Closed, Duplicate
None
Samer Muar (ardicilliq)
Aug 22 2019, 4:20 PM
  • BF Blender
Abid Maqbool (cto.abid)
Dalai Felinto (dfelinto)
Operating system: macos 10.14.6 (18G87)
Graphics card:
  • Radeon Pro Vega 20 4 GB
  • Intel UHD Graphics 630 1536 MB
Broken:
  • 2.80 ,official release (2019-07-30)
  • 2.81.0 189aa32a3ac0, 2019-08-21
First Crash happened while working on Action Animations.
File won't open any longer (crashes everytime)
  • low poly mesh with Low res UV, (texture and material node setup)
  • eevee
  • Armature
  • two open windows (main + side), side has 6 3d views, main has 3d view, timeline and dropsheet (action editor) open
  • multiple set actions
Crashed while trying to set locRotScale on bones
Related Objects
Mentioned Here
P1079 (An Untitled Masterwork)
P1080 (An Untitled Masterwork)
P1081 (An Untitled Masterwork)
rB189aa32a3ac0: Cleanup: vertex coordinate access, naming & minor changes
Samer Muar (ardicilliq) created this task.Aug 22 2019, 4:20 PM
Abid Maqbool (cto.abid) added a subscriber: Abid Maqbool (cto.abid).EditedAug 22 2019, 4:32 PM
@Samer Muar (ardicilliq) Umm! By following same steps you can reproduce the error again?
This file is crashing...
Samer Muar (ardicilliq) added a comment.Aug 22 2019, 4:38 PM
@Abid Maqbool (cto.abid) it's the second time it happened with this project... the first time it happened I managed to reopen it by recovering the last session, but this time I accidentally clicked on another project first and I can't open the file now.... I tried to open it on windows as well (2.81 2019-08-22)....
I can try to reproduce it with a new project.... but I really hope to save this one... :(
Dalai Felinto (dfelinto) lowered the priority of this task from 90 to 30.Aug 22 2019, 5:19 PM
Dalai Felinto (dfelinto) added a subscriber: Dalai Felinto (dfelinto).
It certainly help a lot if you can reproduce from scratch. Regardless, was this file made entirely with 2.80 official release?
This seems like a bug in the derived mesh code generation of normals. Maybe a race condition. It breaks consistently:
Thread 7 "blender" received signal SIGSEGV, Segmentation fault.
#0  mesh_calc_normals_poly_prepare_cb (userdata=0x7fff9a8b74b0, pidx=1024, UNUSED_tls=0x7fff9c8bc4d0) at //source/blender/blenkernel/intern/mesh_evaluate.c:255
Full thread 7 backtrace: P1080
And from other threads: P1079
Or even better, when running with -t 1 --debug-depsgraph-no-threads: P1081
Samer Muar (ardicilliq) added a comment.Aug 22 2019, 5:33 PM
I'm currently trying to repro from scratch... although haven't been able to yet...
The project was originally created with one of the 2.8 beta version... Unfortunately I can't remember which one and I already deleted It (because of the first crash I described above) I pretty sure it was a version from 2019-03-30~
after the first crash it occurred to be that there might be newer versions so I then downloaded the official 2.80...
The model wasn't started from scratch though ... It's from a fbx file (adding file to comment:
and here is the texture it's using:
Samer Muar (ardicilliq) added a comment.Aug 22 2019, 5:36 PM
Dalai Felinto (dfelinto) added a subscriber: Campbell Barton (campbellbarton).Aug 22 2019, 6:04 PM
If the bad file was created with a beta version and you cannot reproduce with 2.80 and on there may be nothing we can do. We are to remove DerivedMesh entirely maybe that will help your case.
@Campbell Barton (campbellbarton) any 2 cents here?
Samer Muar (ardicilliq) added a comment.Aug 22 2019, 11:55 PM
@Dalai Felinto (dfelinto) So there is no way newer release can fix this file or at least make it open so I can somehow export the animations?
Is it possible to somehow get the beta version and try it there? because the crash happened in the official version (the crash that happened in the official version is the one the corrupted it)
Samer Muar (ardicilliq) added a comment.Aug 23 2019, 12:02 AM
Can I manually remove DerivedMesh if I download the source code? can I compile the a local version and fix it there? or somehow comment the crashing code so I can at least save the contents of the file?
Dalai Felinto (dfelinto) added a comment.Aug 23 2019, 12:55 AM
Animations are fine, the issue is somewhere in the mesh. So you can just open a new file and Append the actions from your problematic file.
Here, your FBX imported with the Actions appended from your original .blend:
Samer Muar (ardicilliq) added a comment.Aug 23 2019, 1:14 AM
@Dalai Felinto (dfelinto) Omg I can't thank you enough! Im already knees deep in trying to debug the whole thing, I've already built the project and everything...
So the mesh is problematic?
Should I fix something there?
Do you think it might happen again with this mesh?
And how can I export the animations like you did in case in happens again?
Thanks a lot of the effort again... really appreciate it...
Dalai Felinto (dfelinto) added a comment.Aug 23 2019, 1:25 AM
Since you will now work from the official, stable 2.80 from scratch, I really hope you don't run into any issues. If you do, though, we will be more able to tackle it as a bug.
Yes. It seems corrupted.
Not really, just carry on using Blender.
No idea. I hope it does so we can find and fix the bug, if there is one ;)
I didn't export. I imported them in the other file. Look at the Blender manual on Appending datablocks from other .blend files.
Samer Muar (ardicilliq) added a comment.Aug 23 2019, 1:27 AM
Googled How to do it :D
Should work for me.. I'll just have to save often so I won't lose too much progress if it happens again (hopefully it won't with a new created project)
So you can close the ticket I guess, if you say it's lost anyways and I got my animations :D.
Dalai Felinto (dfelinto) closed this task as a duplicate of T68629: EXCEPTION_ACCESS_VIOLATION when entering Edit Mode.Aug 23 2019, 1:39 AM
